Wix Oil Filter vs Victory Oil Filter - Page 4 - Victory Forums - Victory Motorcycle Forum
 13Likes
post #31 of 39 (permalink) Old 07-19-2019, 05:22 PM
Motorbikerx's Avatar
Bought a couple of K&N oil filters for my 455 Buick, box said Nascar Performance made in USA, filter had Made in CHINA.
Fitted one and had double the correct warm idle pressure (Restrictive filter!)
Emailed the supplier with pics and got a full refund.
Managed to track down a Wix supplier in my capital city Brisbane, as they arent readily available here local, he couriered me two Wix filters, oil pressure back to normal🙂
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #32 of 39 (permalink) Old 07-19-2019, 06:30 PM
ScabbyDoo's Avatar
Been using K&N for quite some time, on my HDs and now on my CC. Never had a failure or problem that could be even remotely linked to the filter. For the couple bucks more than WIX, I'll stay with what I know works.
2014 CrossCountry
B&E Performance "Atom Bombs"
Lloyd'z High Flow Filter
PVcx Dyotuned by JD's Cycle Works
95.5 hp / 112 tq
Klock Werks Windshield
ScabbyDoo is offline
post #33 of 39 (permalink) Old 07-19-2019, 07:14 PM
Originally Posted by whooshbang View Post
having looked at the filtron website i think there are a different company manufacturing the Wix 51356 alternative. I have therefore purchased the original Wix to be on the safe side. Cheers All
D
I wonder if the Filtron in the UK is the XP Wix in the USA...
Maybe there was some kind of patented name issue so they had to call it something else. If this is the case then the Filtron Wix would need to be used with synthetic oil just like the XP filters.
I agree; stick with the original Wix. The Filtron may be too restrictive for semi-synth oil.
whooshbang likes this.
post #34 of 39 (permalink) Old 07-19-2019, 07:21 PM
Originally Posted by Chattanooga Mark View Post
Thank you for the link. A 12 pack comes to $75.97 with shipping to my zip code. The same 12 pack on Amazon Prime is $92.28 delivered.
Careful; that's the wrong part number. The last two numbers are reversed. The correct link for these 12 filters is below.
WIX 51356 Case of 12
The good news is those will still work. They are a match with the 51356 filters.
https://www.oilfilter-crossreference...vert/Wix/51356
Not sure what the difference is. Probably not much if any.
Chattanooga Mark likes this.
post #35 of 39 (permalink) Old 07-20-2019, 10:30 AM
toejam's Avatar
If I remember correctly - which at my age who knows, I believe I read that the only difference was in the length of the filter, one is just a tad longer than stock. Thanks for the catch...
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #36 of 39 (permalink) Old 07-21-2019, 09:49 PM
djh3's Avatar
I run the longer filter, just because. More surface area, more capacity has to be better. Same reason I run a FL1 on my dodge instead of the half sized one. So if you have an Oreilys their store brand filters are made by Wix. I try to stay with either the Wix or Oreilys, I used purolators for a long time but they changed the thread on part and on the RSV at least the filter will not draw down enough to seat.
I will not run a fram on anything, not even the mower. I was working in a Dodge deal and we got a TSB that specifically not to use fram filters on the 5.9 diesels as they were coming apart and the materials were getting into the oil pumps and starving the pump. We had a 4.7 that spun bearings out and lo and behold fram filter.
2013 XCT added Jan 2015
djh3 is offline
post #37 of 39 (permalink) Old 07-22-2019, 12:33 AM
Am I hearing correct?
Synthetic, semi- synthetic, and mineral oils
need different types of oil filters???
Do we have any solid evidence on that?
if do please post links...
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #38 of 39 (permalink) Old 07-22-2019, 07:46 AM
Search engines are your friend.
WIX Filters Launches New XP Line of High Premium Oil Filters
Wednesday, 20 March 2013
XP Scientifically Designed to Maximize Synthetic Oil Performance,
WIX Filters, a member of the Affinia Group family of brands, has launched a new XP line of high premium oil filters engineered to withstand the toughest of driving conditions and scientifically designed to maximize the performance of synthetic motor oils.
WIX Filters - New Article
post #39 of 39 (permalink) Old 08-05-2019, 10:38 PM
djh3's Avatar
I did a couple searches and my take away was: as long as the filter meets you vehicle spec IE: drainback/non-drainback, pressure relief valve/spring and micron filter size. It dont make no never mind. A better filter (higher % @ lower micron) is basically an upgrade.
djh3 is offline
