Wix Oil Filter vs Victory Oil Filter - Victory Forums - Victory Motorcycle Forum
 12Likes
post #1 of 39 (permalink) Old 02-17-2013, 10:41 PM Thread Starter
Rajder's Avatar
Default Wix Oil Filter vs Victory Oil Filter
I know there are some of you guys of use the Wix oil filters. I typically use Wix filters for all of my vehicles. But I noticed a difference between the Wix filter and the Victory filter. The Victory filter is much longer (see picture). I found this interesting because I have always considered the Wix filters the gold standard of oil filters. But if the Victory oil filter is longer one would think that it has an increased filter area over the Wix filter and therefore would have better long term performance.
Has anyone else noticed this?
2011 Cross Country
-Cee Baileys Windshield & Lowers. Victory Lower Bag Rails, Driver And Passenger Backrests.
-RPW Exhaust, Lloydz Air Filter, VM1 Cams, ATS (Timing Wheel), 1/4 turn throttle & IAV. PCV with Custom Tune by Coweta Customs.
105.2 HP & 127 Ft-Lbs on a Dynostar (Eddy Current) Dyno.
Rajder is offline
post #2 of 39 (permalink) Old 02-17-2013, 10:57 PM
sertboy354's Avatar
Default Re: Wix Oil Filter vs Victory Oil Filter
I have seen it before the shorter filter will do as good of a job as the longer I dont think there is that much of a difference in this case in my option
Sent from my SCH-I535 using Motorcycle.com Free App
sertboy354 is offline
post #3 of 39 (permalink) Old 02-18-2013, 05:48 AM
TNXR's Avatar
I wouldn't think it would matter either. I've got a 12 year old chevy truck that I buy what ever oil is on sale and what ever filter is the cheapest/ on sale. All the filters I have bought for it are different sizes but never a problem in the last 250k miles (front diff and water pumps is a different story).
2011 Cross Roads Sunset Red
TNXR is offline
post #4 of 39 (permalink) Old 02-18-2013, 07:09 AM
gibson's Avatar
2012 Fireball Jackpot
gibson is offline
post #5 of 39 (permalink) Old 02-18-2013, 07:09 AM
Pop
I don't imagine that the math is much different one to the other. Didn't I read on here or someplace that Wix is the OEM for Vic?
The conversation would be something like...
Wix: "We have run the numbers and have a filter application that more than covers the Freedom Engine specified requirements."
Vic: "Too cheap and it doesn't have our logo."
Wix: "OK. We'll put your decal on it for a penny a unit and you can mark it up a couple of bucks."
Vic: "How about that and you make the can an inch or two longer and we mark it up another 10 bucks? Wouldn't want folks to think that they could save money by buying the same filter cheaper from you guys."
Wix: "Done! Pleasure doing business with you guys. Now what club do you guys recommend for the hook at the treeline on the 8th hole?"
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #6 of 39 (permalink) Old 02-18-2013, 07:11 AM
gibson's Avatar
Speedblue likes this.
gibson is offline
post #7 of 39 (permalink) Old 02-18-2013, 07:15 AM
saddlebag's Avatar
Originally Posted by TNXR View Post
All the filters I have bought for it are different sizes but never a problem in the last 250k miles.
Prezactly. Motorcyclists worry endlessly over this stuff and 99% of them will never put enough miles on a bikes for it to be an issue if they used cooking oil and bypassed their filter.
2011 Cross Roads
saddlebag is offline
post #8 of 39 (permalink) Old 02-18-2013, 02:49 PM
The Wix 51356 is the equivilent to the Polaris filter, but the 51365 will work too. You will change your oil before the surface area becomes an issue, but next time get the 51356. Same bypass, same max flow, little different burst pressure but not relevent.
mtsiview is offline
post #9 of 39 (permalink) Old 02-18-2013, 09:36 PM Thread Starter
Rajder's Avatar
Sounds good like some pretty good explanations to me. Thanks guys.
2011 Cross Country
Rajder is offline
post #10 of 39 (permalink) Old 02-19-2013, 12:02 AM
The Wix 51358 is the same filter as the 51356 only it's longer for more capacity and is probably very close to the same dimension as the Victory filter in the comparison photo.
40XC is offline
