Front and rear leds - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 02-19-2013, 12:54 PM Thread Starter
Default Front and rear leds
I have just installed my front and rear wbm led lights. I still have to install the load equalizer. I was reading up about guys using the led flash module part number 4013199 for the touring bikes ( replacing it with the acm ) Any body know if this works instead of the load equalizer. I guess I should mention its an 2012 vegas 8 Ball. Also did anyone run into the wires for the lights being reversed for the 2012? or was this just the older bikes?
Thanks, I know this has been beaten around here.
Poppachips is offline
post #2 of 15 (permalink) Old 02-20-2013, 09:27 AM Thread Starter
After more internet fun I realize now my bike does not have the acm and has a flasher module relay instead. Explains why I couldnt find it.
But Im still wondering if the led 4013199 will work instead of the equalizer.
post #3 of 15 (permalink) Old 02-20-2013, 11:37 AM
According to this Thread, It sounds like a direct replacement as long as you're changing all the signals to LED's
https://www.victoryforums.com/showhread.php?t=6772&page=2
2012 Highball w/ Power Commander and RPW Big Slash.
2006 Buell Firebolt XB12R Raced mapped/Gutted Exhaust.
J_Undisputed is offline
post #4 of 15 (permalink) Old 02-20-2013, 02:42 PM
Where did you buy your LED lights? I notice you are in Canada and I can't seem to find a good website in Canada to buy motorcycle parts.
pnm_100 is offline
post #5 of 15 (permalink) Old 02-21-2013, 10:00 AM Thread Starter
I picked them up locally as it seemed only about 30 bucks cheaper than with shipping from on line. Where in canada are you?
post #6 of 15 (permalink) Old 02-22-2013, 09:22 AM Thread Starter
Got everything wires up yesterday and then tested... Just a heads up the 2012 8 ball ( Mine anyway ) the front left signal is wired backwards. I traced the wires back into the head light and in the connector the blue wire is black on the other side and the black wire is blue. Makes you wonder why this would happen from factory.
post #7 of 15 (permalink) Old 03-01-2013, 08:29 AM
noSkills's Avatar
Did you get your load equalizer installed yet? If so where did you put it?
I'm installing LEDs all around this weekend and have my load equalizer on order. Initial tests already show the fast blink symptom.
noSkills is offline
post #8 of 15 (permalink) Old 03-01-2013, 08:31 AM
noSkills's Avatar
Incandescent bulbs don't matter which way power runs through them. I noticed on the back of my 2012 Hammer 8-ball last night that the rear blinkers can't only be installed one way for left and right but both ways for power.
noSkills is offline
post #9 of 15 (permalink) Old 03-01-2013, 11:42 AM
would like to see the LED bulbs you have
post #10 of 15 (permalink) Old 03-01-2013, 11:58 AM
Tims_04V92TC's Avatar
Im not sure as to your question. Are you asking location "where" or which wires to connect the EQ to?? If it is connection, you connect the load equalizer to the ground to that turn signal and to the color designated flash wire. Example of one of my rear flashers
Blk = Ground
White/Pink= Running light
Blue = Turn
As POPs noted, wiring diagrams can sumtimes be wrong, do a quick visual of which element is lit as running light just to double check or run back into your harness. Ground usually becomes common at some point.
You SHOULD need a LE on each seperate turn signal of approx 6ohm at 25 watt, here that would be tapping one end each of the equalizer to the BLK and the Blue. How you connect the equalizer is up to you, if you use inline or "T" style compression wire taps, ensure you wrap well with elec tape. You may find Posi-Taps a better environmental resistance solution but more expensive. heres the link.
http://www.posi-lock.com/posiplug.html
Hope this helps, if not toss a little more info and would be glad to help if I can.
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
