HIFLO oil filter - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 03-02-2013, 02:14 PM Thread Starter
mooch's Avatar
Default HIFLO oil filter
Just wondering if anyone has used Hiflo oil filters. Are they a good filter
2013 xct bronze mist
mooch is offline
post #2 of 21 (permalink) Old 03-04-2013, 07:20 PM Thread Starter
mooch's Avatar
I must be the only one that has used this filter[. ATTACH]10168[/ATTACH]
mooch is offline
post #3 of 21 (permalink) Old 03-04-2013, 08:33 PM
post #4 of 21 (permalink) Old 03-05-2013, 04:53 AM
gibson's Avatar
http://motorcycleinfo.calsci.com/FilterStudy.html according to this study it is just a average filter. It was originally made for a cheaper alternative to the Honda import oil filter.
2012 Fireball Jackpot
gibson is offline
post #5 of 21 (permalink) Old 03-05-2013, 12:55 PM
If you do a search on the net the rumorer is they make K&N oil filters
Guys rate the filter as being good.
I go to auto store pick up WIX for $6.95 and call it good like 90% of the other guys here
post #6 of 21 (permalink) Old 03-05-2013, 01:08 PM
post #7 of 21 (permalink) Old 03-07-2013, 07:19 PM Thread Starter
mooch's Avatar
Thank's guys. my next filter will be a wix filter
mooch is offline
post #8 of 21 (permalink) Old 11-06-2013, 03:29 AM
Tech23's Avatar
Yea, I know this is an old thread.
I was just doing some research on this topic. From what I have read...remember I read it on the internet. The Wix filter is rated at 21 micron and the OEM Polaris filter is rated at 10 micron. While looking into filter specs I read a lot about filter dissections/comparisons and those that did the comparisons/dissections said all the aftermarket filters looked to be identical to the Polaris filter inside. I have no idea how someone would be able to tell what size particles the filter media is capable of trapping by looking at it. A micron sounds real small and in the scheme of things I doubt the difference is noticeable long term. Anyway....
mi·cron
ˈmīˌkrän/
noun
noun: micron; plural noun: microns
1.
a unit of length equal to one millionth of a meter, used in many technological and scientific fields.
Tech23
Tech23 is offline
post #9 of 21 (permalink) Old 11-06-2013, 06:19 AM
Oldman47's Avatar
What you can tell after a filter has been in service for a number of miles is whether one filter plugs faster than another. In other fields I was able to select media based on filter micron size. In those uses the 10 and 20 micron filters were dramatically different. The 10 micron plugged up at least 4 or 5 times faster in actual use than the 20.
Oldman47 is offline
post #10 of 21 (permalink) Old 12-22-2013, 07:21 PM
Motorbikerx's Avatar
Default oil filter
so whats the bottom line here? Victory wants $21 Aus for a genuine fliter, theres a cleanable unit for $189, or a generic one that wont filter as fine but wont block up as easy??
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
