Drive Belt Options - Victory Forums - Victory Motorcycle Forum
 11Likes
post #1 of 51 (permalink) Old 03-10-2013, 10:25 PM Thread Starter
Ferta_McDaniels's Avatar
Default Drive Belt Options
I broke my drive belt today. I'm not really surprised as it is the original belt. There are only 15k on the bike but it is an 04. I was in the throttle pretty good when it broke. My question is are there any options for drive belts besides the stock belt? I was hoping to find something a little stronger than what I had. The bike has a lot of torque so stronger would be better. Maybe something Kevlar reinforced???
PFloyd (Ferta)
2014 Vision Nuclear Sunset
XM Radio Module
Sequential Turn Signals F/R
1/4 Turn Throttle Ring
HID Headlights & Cyclops
Vic Shop Tweaks: 124 HP / 121 Torque
04 Purple Thunder Kingpin (Sold)
Ferta_McDaniels is offline
post #2 of 51 (permalink) Old 03-11-2013, 01:18 AM
BBob is online now
post #3 of 51 (permalink) Old 03-11-2013, 05:34 AM
half_crazy's Avatar
Count the teeth in the belt, my belt is 147 I think...
Gates makes high-strength belts, but the longest one is 139 teeth. I run a Goodyear belt for a Buell 1125R (145 teeth) because of my smaller front pulley. Just got lucky and found that.
2006 Victory Kingpin
half_crazy is offline
post #4 of 51 (permalink) Old 03-11-2013, 12:29 PM
Guys with way more horse power then what you have run belts and they last 80 thousand miles or more.
My guess is your belt was out of alignment.
visionjohnny is online now
post #5 of 51 (permalink) Old 03-11-2013, 12:51 PM Thread Starter
The belt had no alignment or tension issues. It was originally designed for a 92ci engine. It was 9+ years old and I have no idea of the bikes history before I bought it. I read that when Victory introduced the 100 & 106 engines they also put stronger belts on them. Hopefully the replacement belt is beefier than the original.
PFloyd (Ferta)
XM Radio Module
post #6 of 51 (permalink) Old 03-11-2013, 03:19 PM
I have an '04 V92TC, and the belt broke when the previous owner had it a around 7500 miles.
I've got 12,5000 on the bike now. Hopefully, they got it right when it was replaced. the manual says 30k miles I think.
Cloverdale, Calif.
V92TC
(The fast blue one)
Bugkiller is offline
post #7 of 51 (permalink) Old 03-11-2013, 06:58 PM Thread Starter
Just an FYI...The stock 04 kingpin belt (3211088) has 142 teeth.
PFloyd (Ferta)
XM Radio Module
post #8 of 51 (permalink) Old 03-11-2013, 07:10 PM
SilentUnicorn's Avatar
At what pitch?
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
post #9 of 51 (permalink) Old 03-11-2013, 07:20 PM Thread Starter
I think it's a fastball on the outside corner . I read somewhere that the pitch is 14mm but I am not certain.
PFloyd (Ferta)
XM Radio Module
post #10 of 51 (permalink) Old 03-12-2013, 07:45 AM
Or a small rock was introduced between it and the pulley. My old KP had the original belt when I traded it in at 85k miles, and it had the same power specs as your bike. I ran it hard down the 1/4 mile track a few times too. As far as I know, it's new owner is still using the same belt.
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
