Led turn signal problems - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 03-12-2013, 02:33 PM Thread Starter
Default Led turn signal problems
I just hooked up some rear turn signal LEDs on my 2012 hammer 8ball and i lost all turn signals and the tail light. Brake light works ok, headlight works, but no turn signals. Checked the fuse and its fine. I hooked up a load equalizer as well. Any suggestions as to what could be wrong?
2012 Hammer 8 Ball
theblade88 is offline
post #2 of 15 (permalink) Old 03-12-2013, 02:42 PM
CrossRoads's Avatar
1.) Are all turn signals not working? (front left, front right, rear left, rear right?)
2.) When turn signal switch is flipped to left or right, does the turn signal indicator flash? If yes, does it flash normal speed, or does it flash 2-3 times faster than normal?
3.) If you turn on the 4-way flashers, do they work?
4.) Do you have a voltmeter handy?
CrossRoads is offline
post #3 of 15 (permalink) Old 03-12-2013, 02:59 PM Thread Starter
Default Re: Led turn signal problems
None of the flashers work, hazards dont work, and theres nothing on the display to indicate the turn signals are on. Unfortunately I dont have a voltmeter handy
2012 Hammer 8 Ball
post #4 of 15 (permalink) Old 03-12-2013, 03:43 PM
CrossRoads's Avatar
Try swapping the fuel pump relay with the flasher relay, and test again.
post #5 of 15 (permalink) Old 03-12-2013, 03:51 PM Thread Starter
I had to walk away from it for now, I'll give that a shot when I get another chance to tackle it.
2012 Hammer 8 Ball
post #6 of 15 (permalink) Old 03-12-2013, 04:10 PM
CrossRoads's Avatar
Okay. Just make sure when you test it, that the key is in the ON position and that the kill switch is in the RUN position. When you're frustrated about something not working, these little things can easily be overlooked.
post #7 of 15 (permalink) Old 03-12-2013, 04:13 PM Thread Starter
Will do. One thing I forgot to mention is that the fuse for the horn was blown. Not sure if that would make a difference or not.
2012 Hammer 8 Ball
post #8 of 15 (permalink) Old 03-12-2013, 04:24 PM
CrossRoads's Avatar
Yes it does make a difference. Horn and flashers share the same fuse. Replace the fuse.
post #9 of 15 (permalink) Old 03-12-2013, 04:30 PM Thread Starter
that figures. like you said sometimes it's the little things. Thanks for the help!!!
2012 Hammer 8 Ball
post #10 of 15 (permalink) Old 03-12-2013, 10:36 PM
joshn's Avatar
Good to know for in the future! thanks never know when I might need that tid bit of info
2013 Vegas 8 Ball, 6k HID, Hacker Ripper Pipes and FMS
joshn is offline
