Victory Oil-Change Kit - What if it's no longer sold? - Page 7 - Victory Forums - Victory Motorcycle Forum
 64Likes
post #61 of 73 (permalink) Old 10-05-2018, 10:43 PM
djh3's Avatar
Originally Posted by psychodiablo View Post
magnaflow mod. ?
I'm thinking its same as the thrush mod, or glasspack mod. Gut OEM mufflers and install "bullet" muffler inserts.
2013 XCT added Jan 2015
djh3 is offline
post #62 of 73 (permalink) Old 10-06-2018, 12:22 AM
psychodiablo's Avatar
Send a message via AIM to psychodiablo
got it. i was a lil slow on the draw there.
Leesville Louisiana. 2012 cross country, speedo upgrade,forged engine guard,touring sheild, tri oval pipes, Lloyds gen 3 fuel controler, Lloyds highflow airfilter. Lloyds timeing wheel, msd coils,Lloyds 8.2 mm red wires,tank lift/spacers,tank wings,side cover scoops,audio input cord,drivers back rest, 2in pull back bars,polk 5.25 speakers,XC Mag baffles,rockford fosgate pbr400x4 amp,lower wind deflectors,sylvainia ZXE Gold h-11 headlights. rivco hiden hitch. IDMW,FYIYDLMOMB.
psychodiablo is offline
post #63 of 73 (permalink) Old 01-11-2019, 12:34 AM
ObiSteve's Avatar
Jeez fellas, am I being too much of a cheapskate by annealing the sump plug washers to cherry red in a gas flame, then dropping them into water then reusing them?
I did this on Nortons for a dozen years with no problems, it was the shop manual recommendation, and now for 4 years with the Hard Ball. No sign of leaks.
Cheers, Steve.
2013 Hard Ball
Stage 1 mufflers
K&N air filter
Rubber air dam removed
Reflash
Darkside
Whole lot of extra cable ties, shrinkwrap and tape on loom
Hard chrome spherical joints in back
Hammer front guard
Wide Glide fork boots
ObiSteve is offline
post #64 of 73 (permalink) Old 01-11-2019, 06:05 AM
RoteBaron's Avatar
to paraphrase Captain Renault from Casablanca "I'm shocked, shocked to find that innovation and thinking is going on in here! " . Sometimes I've even reused old washers. Still no oil leaks for 5 1/2 years. The horror, the horror......(Gratuitous "Apocalypse Now" reference) (Orrrrr good stuff ObiSteve. We're going to need a lot more af that thinking as time goes on.) LMYR
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg
Victory High Flow Air Filter
2017 Highball - Suede Nuclear Sunset Orange
RoteBaron is offline
post #65 of 73 (permalink) Old 01-11-2019, 07:38 AM
Doesn't heating and rapid quenching HARDEN the metal and isn't the goal for these crush washers to have them a little soft so that they will conform to the shapes of the two mating surfaces (drain plug shoulder and engine case)? If so, why would hardening them help?
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #66 of 73 (permalink) Old 01-11-2019, 07:53 AM
I know that it does not contain the magic formula of Victory oil, but I have been using Spectro Golden 4 20 X 40 Semi Synthetic oil for over a year now and do not think my Victory could run without it. Have also been using the K & N bolt end oil filters for over 20 years on all my bikes that I have owned. Also I reuse the copper washer from time to time if it looks OK. I do recognize I am living dangerously.
cal_105215 is offline
post #67 of 73 (permalink) Old 01-11-2019, 08:06 AM
If you need to replace the washer every oil change on bikes or cars you're doing it wrong. Tight, not crazy.
post #68 of 73 (permalink) Old 01-11-2019, 08:36 AM
mh1
mh1's Avatar
Heating and rapid quenching will harden STEEL, but it will fully anneal copper. Different metals, different metallurgical processes.
Chattanooga Mark and broggyr like this.
2013 Cross Roads Classic
mh1 is offline
post #69 of 73 (permalink) Old 01-11-2019, 04:04 PM
olddad64's Avatar
It depends on the type and makeup of the steel as to whether it will harden when heated and quenched. Doesn't work on all steel.
Chattanooga Mark likes this.
2014 Victory Cross Country Tour. Blue and Silver
Tri-Ovals--Stage 1 download--Loydz Air Filter
Sabertooth Saddle Bag Lights
LED headlights and a few custom engine/transmission goodies
olddad64 is offline
post #70 of 73 (permalink) Old 01-11-2019, 06:15 PM
BP6666VR's Avatar
I just ordered Spectro Golden 4 Semi-Synthetic 20w50 Case of 6x1L
I hope it will arrive to were i live,
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
