Vic Oil Lab Results - Victory Forums - Victory Motorcycle Forum
post #1 of 27 (permalink) Old 03-21-2013, 06:31 PM Thread Starter
Rebel Biker's Avatar
Default Vic Oil Lab Results
Not sure if ya'll can see all the details with the document being resized. Came back abnormal and close to critical. There was 4,329 miles on this oil. The Viscosity did break down BUT it wasn't the oil's fault. Notice the orange color, 3.7% fuel contamination! Holy crap! Also the Nickel traces were in the normal range but barely. Comments suggest possible valves, stems or guides as the culprit. Silicon was in the normal range but like the Nickel...barely. The butt load of fuel in my oil is a pretty clear indication of a fuel leak...now that I think about it, I've had hard starts in the morning where it cranks and cranks and cranks then finally catches but smells of fuel. Thought it could be due to the harsh cold I been riding in but now the light bulb comes on.
This analysis scares me so I took my bike to the dealer within a couple hours of seeing this report. I handed them a copy of the results and they'll go through the bike.
Folks, this is why oil analysis can be $ well spent.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #2 of 27 (permalink) Old 03-21-2013, 07:17 PM
vindex1963's Avatar
Attachment 11866
I had high fuel because of a bad throttle positioning sensor.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 27 (permalink) Old 03-21-2013, 08:39 PM
ndabunka's Avatar
I don't think you can get fuel in your OIL from a bad throttle sensor, can you? You may get poor fuel economy but fuel getting into the oil itself would seem to be indicative of other malady's (like piston or value seals, right? Vindex did the right thing taking it to his dealer for review of the engine itself.
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #4 of 27 (permalink) Old 03-22-2013, 09:22 AM
gibson's Avatar
To rich will make it sucked into and around the rings , so yes a bad sensor can run it to rich..
2012 Fireball Jackpot
gibson is offline
post #5 of 27 (permalink) Old 03-22-2013, 09:49 AM
lets us know what your dealer finds
hammer316 is offline
post #6 of 27 (permalink) Old 03-22-2013, 10:38 AM
SilentUnicorn's Avatar
I was thinking leaky injectors?
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
post #7 of 27 (permalink) Old 03-22-2013, 12:51 PM
m
That's what I was thinking too.
oldyaler is offline
post #8 of 27 (permalink) Old 03-22-2013, 12:56 PM Thread Starter
That would be my guess as well. Like I mentioned earlier, sometimes when its cold (first start) it would crank and crank then finally start. I'd smell fuel. I've also noticed black smoke on start up. Not sure what's normal and what's not. On a car, that's a sure sign fuel is sitting in your cylinders and 9 times out of 10 it's the fuel injector leaking down.
post #9 of 27 (permalink) Old 03-22-2013, 01:48 PM
A compression or leakdown test would help with diagnostics. It would also tell you if any damage has been done to the cylinder walls.
You mention Nickel from your analysis. Does any one know if the cylinders are Nicasiled?
m
post #10 of 27 (permalink) Old 03-22-2013, 02:12 PM Thread Starter
m
Yeah, my dealer's tech had that thought going through his head too. He said they'll do compression tests on it when they're going through the bike.
I'm a little bit down over this. One because my bike is at the dealer again and I'm not going to be able to ride it today. The other, I just past 5,000 miles and I've had the cruise control module replaced under warranty (they redesigned it to be completely water proof and I have the new version now), the rear pulley replaced under warranty (all good now), and now this...whatever this turns out to be. 5,000 miles! It's bull! With all my goodies, I'm near 20k in this bike. I'm very disappointed with the trouble I'm having thus far and I hope this will be my last issue for a LONG time.
I still love my Pin and I still believe I have the badest cruiser on the road not to mention the best looking cruiser
Don't nobody get me wrong. I'm in love with my bike and I do not regret my purchase. If I had to do it over again, I'd buy the exact same thing. I just wanna ride...trouble free.
