Barnet clutch issues - Page 2 - Victory Forums - Victory Motorcycle Forum
 11Likes
post #11 of 19 (permalink) Old 03-26-2017, 01:13 PM
you should be able to ride 80K or more before doing a clutch.
When your in Daytona or five o'clock rush hour traffic. Always get your bike in neutral when sitting still. When you have the clutch lever puller in your causing the clutch to heat up.
post #12 of 19 (permalink) Old 05-02-2018, 12:59 PM Thread Starter
Bill Ragusa's Avatar
Update: getting no more than 2 -3 months 3-5k miles from my Barnett Clutch packs. Just came back from leesburg bikefest and the clutch went after my afternoon ride down Main Street.
Working with my mechanic on using the oem replacement clutch. I BETTER get at least 30k miles from this change over!
B. Ragu
09 Vision
Daytona Beach
Bill Ragusa is offline
post #13 of 19 (permalink) Old 05-02-2018, 06:20 PM
Motorbikerx's Avatar
Mate there is definitly something wrong.
Without a doubt.
My clutch has almost 80K miles on it and it cops a lot of abuse.
However...Im a stickler for maintenance.
Gotta have freeplay
Edit...when I say abuse..its either in or out. .I rarely have to slip it.
It wears when it slips.
Fully engaged or fully disengaged should give stuff all wear.
On a properly adjusted system.
Chattanooga Mark likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #14 of 19 (permalink) Old 05-02-2018, 09:34 PM
depot picker's Avatar
[QUOTE=Bill Ragusa;2505449]Update: getting no more than 2 -3 months 3-5k miles from my Barnett Clutch packs. Just came back from leesburg bikefest and the clutch went after my afternoon ride down Main Street.
Sent from my iPhone using Tapatalk[/QUOTE
No play in the cable or you always have it half engaged.
depot picker is offline
post #15 of 19 (permalink) Old 05-03-2018, 08:35 AM
[quote=depot picker;2505585]
Have you talked to Barnett about it? Maybe they have a suggestion.? I have used the Barnett clutch in all three of my last three bikes and so far [knock on wood] I have had no problem with them. Are you sure they were installed correctly? I know there are no real instructions for installing them from Barnett. They just say follow your bike manual.
Bill Ragusa likes this.
cal_105215 is offline
post #16 of 19 (permalink) Old 05-03-2018, 01:08 PM
Guys vision have hydraulic clutch. The 8 ball has a cable.
I'm pretty sure he's hydraulics they have no real free play like a cable
post #17 of 19 (permalink) Old 05-03-2018, 10:17 PM
Thank you for the clutch video. This is the first one I've seen so I also followed the link and watched a few other ones as well. It looks easier to do this work that I thought it would be. With the exception of needing the clutch tool, home made or purchased. You just have to love a YouTube certification!
Fortunately my clutch is still working perfectly after 56K miles. Yes, I have plenty of free play in the cable adjustment. And no, I don't let it slip much.
Though I've heard it stated both ways with the Victory clutch at a redlight. Some say to keep the clutch lever pulled in and the bike in gear and some say to put the bike in Neutral with the clutch lever out.
I was under the impression that with the clutch lever pulled in, the clutch plates were separated and therefore allowed to be cooled by the oil being able to circulate between them. With the clutch lever out and the bike in gear, aren't the clutch plates locked up and the oil is mostly squeezed out from between them?
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #18 of 19 (permalink) Old 05-04-2018, 05:42 AM
At lights, keep it in gear with the clutch in. This will allow you the quickest escape if necessary, and you won't be holding up traffic when the light changes.
post #19 of 19 (permalink) Old 05-04-2018, 12:46 PM
Bill Ragusa
long as your going threw so many clutches that are not cheap. Do yourself a favor and go see Kevinx he is one of the top Vic mechanic in the USA. Call him and at least talk to him
17708 High Springsw Main St
High Springs, Florida
Get Directions
@kevinxsouthernmotorworx
Send Message
Call (352) 215-3253
