Specs 100 cubic inch Engine - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 03-26-2013, 06:43 AM Thread Starter
New Member
Default Specs 100 cubic inch Engine
Does any one know the torque and Hp rating of the 100 ci Freedom engine? It troubles me that most past ads do not state these facts...
Thank you
-CRod
charlier3355 is offline
post #2 of 3 (permalink) Old 03-26-2013, 07:55 AM
half_crazy's Avatar
The 100" in 2006/2007 made 75 HP/92 Ft-Lbs to the rear tire on average out of the crate.
Totally stock 2008 Kingpin 100"
2006 Victory Kingpin
half_crazy is offline
post #3 of 3 (permalink) Old 03-26-2013, 09:51 PM
Mine made 87 hp and 92 tq with s&s filter and hacker 2 into 1. I wish I would have dynoed it to start but I didnt. I did before and after on cam swap and ported heads. I will have in few weeks another dyno from rev limiter change and torque tubes.
100 ci hammer [email protected]
hammerstang is offline
