Oil Cooler Leak - Need Help - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 03-27-2013, 08:36 AM Thread Starter
wrightek's Avatar
Question Oil Cooler Leak - Need Help
Okay for a little background, I just installed new pipes on my 2012 Kingpin and in the process (after a few hours of frustration) I removed the oil cooler to give myself room to swing the header around the bike which worked like a charm to get the pipes on. However after reassembling I apparently didn't get the oil lines seated all the way into the oil cooler which lead to the oil cooler puking oil onto my floor, I got the engine stopped immediately so no harm, no foul. I gingerly used some slip joint pliers to seat the oil lines onto the o-rings and it worked, I took the bike for a ride around town to test out the pipes and constantly watched for leaks and it was fine. Once done with my test ride I parked the bike and because of this wonderful Ohio weather it's been parked for a few weeks now. I started it up last night to let my buddy hear the new pipes and it started leaking from the oil cooler lines again, this was a pretty good leak too.
Now I'm assuming that I extruded, twisted, crushed or otherwise damaged the o-ring in some manner. Does anybody know what size o-ring I need as a replacement, so I can avoid a trip to the dealer? Also, I don't see any good way to really get ahold of the oil line to seat it into the oil cooler, any suggestions?
2012 Kingpin
Thor Exhaust, PC-V + AT, K&N, HID Headlight, Viking Saddle Bags, Grasshopper Sissy Bar
wrightek is offline
post #2 of 2 (permalink) Old 03-27-2013, 09:35 AM
Tang's Avatar
Looks like you will need part 10 and 11 on this diagram: Link
2013 Victory Highball - Trinity
Sioux Falls, SD
  • Victory Black Straights Exhaust (baffles removed with lollipops added)
  • Victory Stage 1 Upgrade Flash
  • Arlen Ness Big Sucker Air Intake
  • Victory 2" Forward Control Extensions
  • Victory Cruise Control
  • Victory Speedometer Upgrade with Temp Sensor
  • Victory Passanger Seat with Pegs
  • BDD Custom Solo luggage rack
  • Rear LED Signal Bar
  • Black Arlen Ness Teardrop Mirrors
  • Shinko 777 Whitewall 170 Series Rear Tire
Tang is offline
