Home made baffles write up. Monster thunder copy cat - Victory Forums - Victory Motorcycle Forum
post #1 of 29 (permalink) Old 03-27-2013, 10:17 PM Thread Starter
Rebel Biker's Avatar
Default Home made baffles write up. Monster thunder copy cat
I didn't like the sound of the stock exhaust so I cut, hacked and drilled on my stock baffles. I couldn't get the sound I wanted and I wasn't worried about destroying my stock baffles because my fall back plan was to order some Monster Thunder Baffles from bigcitythunder.com Well, I gave them a call with the specs of my X-Bow exhaust in hand. Pipe I.D. 2-5/8" and baffle O.D. 2.6" (just a hair under the pipe I.D.) Turns out they don't make baffles that large for the X-Bow exhaust.
I talked to a forum member about making a set similar to the Monster Thunder original series but then decided to try it myself. I ordered a section of 2" O.D. aluminized steel exhaust pipe, four 2.5" O.D. to 2" I.D. aluminized steel exhaust reducers, a couple 3/4" O.D. steel washers and a couple 1/4" - 20 steel hex head bolts from summit racing.
I measured and marked the reducer 1.5" up from the step down, then wrapped duct tape around the reducer at my mark so I get a straight line all the way around the reducer and marked the edge with a black sharpie.
I used a .040 cut off wheel and cut just outside my mark leaving just a little bit on the outside.
I used a grinding wheel to grind the metal down to the black line. I did it this way just so I don't accidently cut too much on the inside of my line.
I used a gasket remover attachment on my angle grinder to get all the sharp burs off. Not trying to get it perfect, just enough so I don't cut myself handling the baffles.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #2 of 29 (permalink) Old 03-27-2013, 10:21 PM Thread Starter
I measured a 6” section of the 2” O.D. pipe and marked it then I used the duct tape to go around the pipe to mark and obtain my straight line.
I used the .040” cut off wheel to cut the section of pipe.
I slid the small end of each reducer over the pipe so that the edge of the pipe stops right before the reducer enlarges. I tack welded each reducer just enough to hold the pipe incase I need to grind off the tack weld and adjust.
After the baffle got tack welded, I test fit it to my pipe. It slid in so I’m ready to proceed.
I put a steel wire wheel on my grinder and removed the aluminized coating around the end of the reducers where I’ll be making my welds and also removed the stickers.
post #3 of 29 (permalink) Old 03-27-2013, 10:27 PM Thread Starter
One baffle just tacked and the other ready for more welding.
Here is the inside of the baffle, you can see the reduction will provide just a little back pressure but still an open pipe.
Both baffles have been tacked I’m ready to drill my hole for mounting.
I used a very small drill bit to get a pilot hole before drilling with a ” bit.
I used a ” drill bit to get my final mounting holes on the baffles, I wallerd the bit around so it’s not such a tight fit getting my ” bolt to slide in. I also ran a bead around the entire reducer on the inside (closest end to the engine) just to prevent any possible whistling. It’s not pretty, I’m not a welder. Because of that I’m almost not sorry about the blurry pic.
post #4 of 29 (permalink) Old 03-27-2013, 10:32 PM Thread Starter
I used the same cut off wheel I been using to cut my material to cut a notch on the end of the ” bolt that I ordered. I’m going to use this to make a lollipop.
With the washer sitting inside the slot I cut into the bolt, I welded the washer to the bolt. Watch your heat, I burned through the washer pretty easy.
With the washer welded to the bolt, I used my cut off wheel to cut the hex head off the bolt.
I used needle nose vice grips to hold the lollipop in the baffle while I welded the bolt to the inside of the baffle. I placed it right on the edge of the 2” pipe inside.
That’s it, time to mount the baffles inside the exhaust and see what it sounds like.
Again, I'm not a welder or a metal fabricator so these may not be the prettiest baffles around but they'll be hidden inside my exhaust anyway. If I get the sound I was after then I'm a happy biker.
(next up...a video of the start up)
post #5 of 29 (permalink) Old 03-27-2013, 10:36 PM Thread Starter
And here it is, took me 3 hours which is probably longer than it should take.
I must say, I'm a happy biker. This is the sound I was after. You can definitely hear it at an idle, sounds like some muscle when you rev it. I took it for a short ride and it has that nice deep rumble I was looking for.
post #6 of 29 (permalink) Old 03-27-2013, 10:46 PM
When you can't get what you want, do it yourself. Nice job. Good sound, good results.
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
post #7 of 29 (permalink) Old 03-27-2013, 10:58 PM Thread Starter
Thank you!
post #8 of 29 (permalink) Old 03-28-2013, 06:43 AM
Pop
... and a good write up.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #9 of 29 (permalink) Old 03-28-2013, 07:08 AM
PhilC64's Avatar
Sounds just right! Nice job!
2015 XCT - Flying lounge chair
PCV, ATS +4, Lloydz filter, VM1-HPT cams, and Freedom True Duals.
2004 King Pin - 100 cid Big Bore, Ness Intake, Victory Performance Exhaust
2010 XR - Road toy
PCV, ATS +4, Lloydz filter, VM1-DR cams, and Freedom True Duals - traded
Cam Swap write up for X Series bikes:
https://docs.google.com/open?id=0B95...YW1XVXFpeU9fUQ
PhilC64 is offline
post #10 of 29 (permalink) Old 03-28-2013, 07:12 AM
saddlebag's Avatar
Wow Rebel, very impressive. While it doesn't have the potato potato thing it definitely has that American muscle sound. First time I ever recall hearing such a voicing come from behind a Victory. And who ever guessed that all it took was dangling a washer at the output?
Now for the important part. How does the bike run when it's not idling?
2011 Cross Roads
saddlebag is offline
