Crush washer - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 03-28-2013, 08:06 PM Thread Starter
Atbyrne's Avatar
Default Crush washer
What size crush washer do I need for the top brake line on my front brakes? I am getting a super small leak and don't want to try and together it any more.
2011 Cross Country
PCV with Vic filter
Witchdoctors Muscle Mufflers
Painted inner fairing
Magnum 21" Wheel and Fender
Custom mounted CVO Tour Pak
Vicbaggers Bars, speaker grills,
and bezels
Atbyrne is online now
post #2 of 4 (permalink) Old 03-30-2013, 03:20 PM
gibson's Avatar
6 7556028 WASHER,BANJO,COPPER 4 Usage
6 7556028 WASHER,BANJO,COPPER v92.jpg this is from Victory web site. 7556028 is the part number.. There is 4 washers on the line with the same part number..
1 5131657 LEVER-HAND,FRONT BRAKE 1 Usage
2 2050079 M.CYL ASM,F.BRAKE,14MM 1 Usage
3 2201215 KIT,HDWE,FRT.M/C LEVER (Incl. Pin and Nut) 1 Usage
4 2201216 KIT,HDWE,FRT.M/C CAP (See Footnote) 1 Usage
5 2201182 KIT,HDWE,FRT.M/C SIGHT (Incl. O-Ring, Sight and Clip) 1 Usage
7 1930848 BOLT,BRAKE,BANJO,SPCL 2 Usage
8 1930871 HOSE,F.BRAKE,(CRUISER) 1 Usage
9 7517406 SCREW 1 Usage
10 2201173 KIT,BLEEDER SCREW,BOOT (See Footnote) 1 Usage
11 7517419 SCREW,SOCHD,M10X25 2 Usage
12 2201176 KIT,PINS,CLIPS,SPRING,FRONT 2 Usage
13 1930850 CALIPER ASM,FR,4 PISTON 1 Usage
14 2201170 KIT,BRAKE PAD,FRONT (2 Per) 1 Usage
15 4110242 SW,STOP,MICRO,FRONT 1 Usage
16 2201217 KIT,HDWE,FRT.M/C CLAMP (Incl. Clamp and Screws) 1 Usage
17 2201218 KIT,HDWE,FRT.M/C PUSHROD Substituted by 2050079 (Incl. Pushrod and Boot)
2012 Fireball Jackpot
gibson is offline
post #3 of 4 (permalink) Old 03-30-2013, 04:51 PM
If your dealer has none take old one and go to honda show or kawie
and if the don't try h-d
am guessing 10mm
post #4 of 4 (permalink) Old 03-30-2013, 06:53 PM
lunaticrider's Avatar
Most if not all automotive parts stores will carry them, pretty standard across the board...
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
