Fuel Tank Capacity - Victory Forums - Victory Motorcycle Forum
 19Likes
post #1 of 39 (permalink) Old 09-13-2017, 08:40 AM Thread Starter
JC In AZ's Avatar
Default Fuel Tank Capacity
This may be one of those 'duh' questions, but this really has me stumped..
Owner's manual says fuel capacity is 5.8 gal. When I run the level down to where the low fuel light comes on, range usually indicates around 40-45 miles, which, I assume, is about 1 gal or so. So, if I do the math right it should take more than 4 gal.
Yet, when I fuel up, it seems to only take a little more than 3 gal to fill up. So my question is; is MOM overstating fuel capacity, is the fuel range really off, or am I just not getting it.
Now, I know that the range is only a 'best guess' and not to solely rely on it, although it does come fairly close to the average MPG.
As an aside; I almost always start looking for gas station when there is on'y 1/4 tank left, so I don't worry to much about running out of fuel. I also know that a lot of things affect your mileage, so I guess I am more curious than anything else.
But I do want to know where that extra gallon went.
Thanks in advance your feedback.
'Stumped in AZ'
JC
"Christine" 2017 Victory Cross Country
Victory passenger backrest
Victory luggage rack
Kuryakyn driver backrest
Long Ride Shields ReCurve windshield
https://www.victoryforums.com/signat...ic169690_1.gif
JC In AZ is offline
post #2 of 39 (permalink) Old 09-13-2017, 10:05 AM
ammo_umb's Avatar
Fuel capacity is up to mom but fuel economy is up to each rider. If you search the forums you'll find that most people (a lot of which never had a fuel meter before their Vic) tend to fill up at intervals rather than trust a computer calculated guess.
I ride 10,000 plus miles per summer with a friend that rides a street glide. We both fill up at the same time at around 180 miles. Depending on how fast the 180 miles went we both put about 3.1 gallons in if we've averaged under 80 mph or 3.4 to 4.1 if we've averaged over 80 mph.
Results will vary depending on speed, weather, traffic, elevation, temp, etc...
Retired USAF, IYAAYAS!
ammo_umb is offline
post #3 of 39 (permalink) Old 09-13-2017, 12:01 PM
Yep, it's a quirk with the X bikes, most noticeable on the XC's. These bikes use an inside the tank fuel pump that relies on the fuel to keep it cool so in practical use you really should plan on filling up at no less than 1/4 tank; before that if it isn't inconvenient.
It will handle the occasional extreme low fuel level but I wouldn't make a habit of it.
The fuel sensor in these bikes aren't linear either. They move slow as heck at full(ish) tank mark but move very fast between 3/4 and empty. You can stop looking at the fuel gauge and use your odometer like many folks do if that works better for you. Just fill up at the 150 miles point so if you find yourself having to go farther for gas; you won't run out. I've ran mine almost to empty and got 225 miles. I think, IIRC, I put in 5.7 gal at that point and felt lucky to not run out due to my stupidity.
My KP doesn't have a gauge which I found to be okay on an 04 but all bikes should have a fuel gauge by 2007 or so but Victory chose not to do that with the steel frame bikes for whatever reason. I just fill up sometime after 100 miles on that bike even though I could probably go another 60-80 miles before running on fumes.
post #4 of 39 (permalink) Old 09-13-2017, 12:06 PM
Wouldn't it be cool if someone made an emergency can of gas about the size of a 16 can of beer that didn't go bad as long as it wasn't opened? I'd have a couple of those bad boys, one in each saddle bag of both bikes in a protective container; just in case I or someone needed it.
RICZ likes this.
post #5 of 39 (permalink) Old 09-13-2017, 12:50 PM
My tank once went bone dry at 260 miles. Light goes on with about 1.5 gallons remaining. When the light comes in, I mentally figure I have a max of 60 miles left, using a low mpg of 40. When in doubt.....
olddad64 likes this.
post #6 of 39 (permalink) Old 09-13-2017, 02:14 PM
archaicguy's Avatar
https://www.revzilla.com/motorcycle/...1l-fuel-bottle
2016 Cross Country
1969 Firebird
1979 10th Ann. Trans Am
1979 Solar Gold Trans Am
2010 Challenger R/T - Plum Crazy Purple
archaicguy is offline
post #7 of 39 (permalink) Old 09-13-2017, 02:19 PM
Originally Posted by archaicguy View Post
Finding a container isn't the problem. The problem is the fuel starts going bad after just one month. I suppose someone could go through all the trouble to put the old gas in their tank at every fill up and put new gas in the container each time but that isn't what I was hoping for one day.
A literal pop top can of gas that doesn't go bad so it will be there 5 or 10 years down the road if needed without having to change out the fuel in it every month.
I greatly appreciate the effort to find that though.
WSealey likes this.
post #8 of 39 (permalink) Old 09-13-2017, 05:12 PM
It doesn't seal and keep gas fresh but it is a comfort having it. I carry one when heading out on road trips.
Reda Innovations Official Website
My gas light comes on at about 140 miles depending on wind and twist. My bike averages 38-39 mpg consistently no matter my twisting style. Most I have put in has been just shy of 4 gallons.
...."soak it all in, it's a game you can't win"
stilcrazee is offline
post #9 of 39 (permalink) Old 09-13-2017, 05:35 PM
I've seen those before. Great idea for HD saddlebags. I looked but couldn't find how much they hold; do you know?
post #10 of 39 (permalink) Old 09-13-2017, 05:44 PM
arkiebiker's Avatar
I had one of the REDA Innovations gas cans about 6-7 years ago...but the lid bound up on it...it appears that they have addressed that and some other issues with a new version of this can.
Searcy, AR
Blytheville, AR (Hometown and the BEST BBQ Sandwiches in the world)
Arkansas Bikers Website
http://www.arkansasbiker.net
Garmin Zumo GPS Forums
http://www.zumoforums.com
arkiebiker is offline
