Vision Audio - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 09-16-2017, 08:28 PM Thread Starter
RoysVictory's Avatar
Thumbs down Vision Audio
Have a 2012 Vision. I plugged my Ipod into the 30 pin connector in the side pocket, put the source on AUX. All I get is a static sound. Anyone know what the problem is or what I am doing wrong?
Also does anyone use an adapter that connects to the 30 pin connector to make the connection Blue Tooth. If so what is your experience with this system. Thanks
RoysVictory is offline
post #2 of 4 (permalink) Old 09-16-2017, 09:29 PM
VicVisionBulldog's Avatar
I use a Coolstream Duo on my 08 for Bluetooth. Works great.
As for the static I think I would pop the center dash out and make sure the plug is connected directly to the stereo.
VVB
13 Vision Tour - PCV, Top Filter, Stage 1 Pipes, TW @ +4, Metz 888s
VicVisionBulldog is offline
post #3 of 4 (permalink) Old 09-16-2017, 09:29 PM
RoteBaron's Avatar
Default Ipod
Could be the IPOD database just needs to be rebuilt. Happens to me when I add or delete music. There's a FREE program called "Media Monkey" that will help with that. Also, does it come up "AUX" or "(Your IOPD's name) IPOD" when you turn it on? If it comes up "AUX" it could be the IPOD just needs to charge a few seconds then it will change to IPOD. If that doesn't sort it, it could be you need to get an update from the dealer to accommodate the change. My 13 came right up when I added the cable but when I bought the cable the dealer said he's update my system if need be.
No idea on the Bluetooth but Victory has (Had?) a Bluetooth dongle so suspect the 30 pin conversion might not work very well but that is a wild guess.
Good Luck
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg (Soon to go)
Victory High Flow Air Filter
Soon to tune with Maximus
2017 Highball - Suede Nuclear Sunset Orange
Xbow exhaust, High flow air filter, Lame stage 1 update (MEH)
RoteBaron is offline
post #4 of 4 (permalink) Old 09-16-2017, 09:41 PM
The dongle and 30pin adapters are two different animals. As long as the Bluetooth receiver is good it will work well on the bike. I have a 30 pin on 08 and one plugged into my Aux cable on my 13. Both work great and I use them exclusively to stream Pandora.
VVB
