Throttle Cable - Victory Forums - Victory Motorcycle Forum
 7Likes
post #1 of 14 (permalink) Old 09-17-2017, 08:36 PM Thread Starter
Default Throttle Cable
I was messing with the headlight and for some reason my throttle push cable decided to start binding. Anyone else have this issue? It's not binding on either end. Took the gas tank off and took apart the throttle to check. Is my only option replacement? Is it really bad to run without a push cable?
2006 Vegas 8-Ball
Slimjim44 is offline
post #2 of 14 (permalink) Old 09-18-2017, 02:54 AM
Interesting question. If the spring is strong enough to return to the idle position; I can't see the harm in running it like that while you wait on a new push cable.
Bikes have been running without push cables for more than a hundred years. I always thought it was more of a safety thing than anything else just in case the spring broke. Never heard of a spring breaking yet though.
Your bike your call but if it were mine and it returned to the idle position without the push cable; I'd run it.
I'm wondering if the cable wore through the inner sheath somehow and that's why it's binding up. Maybe when it's off the bike you'll be able to figure that out.
post #3 of 14 (permalink) Old 09-18-2017, 05:15 AM
depot picker's Avatar
Check your work. It is probably getting squashed by something you took out.
BBob and Motorbikerx like this.
depot picker is offline
post #4 of 14 (permalink) Old 09-18-2017, 10:39 AM Thread Starter
That was my first thought. All the electrical that runs into the headlight is on the left side of the bike though, and that's where the pull cable is. That's where I was first checking for kinks. The pull cable snaps back like it should with the push cable disconnected though and I can feel the push cable snagging when I move the cable by hand.
2006 Vegas 8-Ball
post #5 of 14 (permalink) Old 09-18-2017, 10:44 AM
If it feels like it's snagging on something inside the inner sheath then my guess is the cable itself frayed. The only fix for it is to either make a new inner cable with the correct ends (good luck finding someone with the correct molds) or get a new push cable. If the inner sheath is damaged the unit is shot.
Probably cheaper and faster to get a new cable.
Slimjim44 likes this.
post #6 of 14 (permalink) Old 09-18-2017, 02:17 PM
the cable on the left is for starting many refer to it as a choke cable. The two cables on the right are your throttle and return cable.
so are you asking about the 2 throttle cables or are you asking about the chock cable. I'm guessing the chock cable has no return spring.
post #7 of 14 (permalink) Old 09-18-2017, 03:00 PM Thread Starter
I mean on the left side of the neck. Fast idle is on the left handle bar and runs on the left side of the neck and under the left side of the gas tank along the frame. The throttle cable (pull cable) is on the right handle bar and runs on the left side of the neck and under the left side of the gas tank along the frame. The return cable (push cable) is on the right handle bar and runs on the right side of the neck and under the right side of the tank along the frame. The electrical runs on the left side of the neck under the gas tank and all goes into the headlight, makes connections, and comes back out the headlight (for the Vegas at least).
Since I was only messing with the electrical, I assumed it was the throttle cable that had an issue. When I took apart the throttle controls on the right handlebar, I figured out it was actually the return cable that was binding. I'm going to try an lube and adjust it this week. Haven't decided if I'll replace both throttle cables or just run with no return cable. I've read that some people like a sticky return, almost like cruise control, but I can't get used to that feeling.
2006 Vegas 8-Ball
post #8 of 14 (permalink) Old 09-20-2017, 09:28 AM Thread Starter
Adjusted at the hand controls and gave both cables a lube. That did the trick. The push cable actually gets pushed back by the spring now.
BBob and visionjohnny like this.
2006 Vegas 8-Ball
post #9 of 14 (permalink) Old 09-20-2017, 09:33 AM
Always appreciated when the solution found is posted so the next person has something to check before asking the same question.
Note: This may work permanently or just for a while. Throttle cables normally don't get lubed so this may indeed be a frayed cable caused by being squeezed at some point. If you have the wherewithal; it wouldn't hurt to get a new cable or even set of throttle cables.
Cheers and Regards!
Chattanooga Mark likes this.
post #10 of 14 (permalink) Old 09-20-2017, 05:59 PM
cra-z1's Avatar
Not sure what model you have but the push cable will also disengage the cruise control if you have one. If in cruise you can close the throttle which will disengage the cruise otherwise it is a safty feature to help close the throttle if it sticks.
Coeur d Alene Idaho, formally MPLS. 2009 KingPin, 2011 KingPin 8 Ball,
cra-z1 is offline
