Are side covers interchangeable ?? - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 20 (permalink) Old 09-21-2017, 02:43 PM Thread Starter
Dahammer's Avatar
Default Are side covers interchangeable ??
Guys, as title suggests, I would like to know if you can take the side covers off of another model Victory, let's say like a Kingpin or vegas, and snap them onto a hammer ???
In other words, are the mounts located at exactly the same place to allow the covers to snap into place from one bike to another. ???
My Hammer has the hugger rear fender with a different seat. So the rear original fender mounts are not an issue, since they were cut-off
Thanks.
2009 Hammer S
Ottawa, Canada
Dahammer is offline
post #2 of 20 (permalink) Old 09-21-2017, 06:40 PM
half_crazy's Avatar
Your side covers don't look right... there's a gap...
The best way to know is look up the part numbers... if they are the same, then you're good.
2006 Victory Kingpin
half_crazy is online now
post #3 of 20 (permalink) Old 09-21-2017, 06:40 PM
Motorbikerx's Avatar
good question...I dont know...maybe check part numbers or find a Vegas owner and try swapping
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 20 (permalink) Old 09-21-2017, 06:42 PM
Agree, ...certainly dont look right...try raising the back of it...get the front away from the hot zorst
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #5 of 20 (permalink) Old 09-21-2017, 06:48 PM Thread Starter
Dahammer's Avatar
I know there' s a gap, hence why I am asking... I guess you mean the part numbers of the mounting bracket. Good idea... Now, I begin to search for the parts diagram. Thanks.
Sent from my E6653 using Tapatalk
2009 Hammer S
Ottawa, Canada
Dahammer is offline
post #6 of 20 (permalink) Old 09-21-2017, 06:51 PM
the partr numbers of the Sidecovers.
just looked at your other pix and yeah it looks so wrong, raise the back of the sidecover
EDIT...goes downstairs to pop a sidecover and see what you mean
I see ..only the top mount is a fixed part of the frame the others are bolt on...yep search polaris part numbers
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #7 of 20 (permalink) Old 09-21-2017, 06:57 PM Thread Starter
Dahammer's Avatar
Thanks.
2009 Hammer S
Ottawa, Canada
Dahammer is offline
post #8 of 20 (permalink) Old 09-21-2017, 07:11 PM Thread Starter
Dahammer's Avatar
In the early conquest customs days on their Super bee, they had the same problem. They had that gap too. Then they took I believe, another models sidecover and fixed that problem... See pics...
2009 Hammer S
Ottawa, Canada
Dahammer is offline
post #9 of 20 (permalink) Old 09-21-2017, 07:14 PM
sidecover on yellow bike certainly different pic to pic....give em a ring
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #10 of 20 (permalink) Old 09-21-2017, 07:26 PM Thread Starter
Dahammer's Avatar
I asked cause I was certain that it was a conquest custom modded hammer... All I was able to get is..." yeah, that's not our kit"...
2009 Hammer S
Ottawa, Canada
Dahammer is offline
