Brake pad recommendations - Victory Forums - Victory Motorcycle Forum
 35Likes
post #1 of 58 (permalink) Old 09-28-2017, 09:35 AM Thread Starter
deepstuff's Avatar
Default Brake pad recommendations
Ok, its time for new pads. What should I look for? Whats the difference? My bike is parked half the year and has a lot of chrome. I want good brakes without corrosion or brake dust stuck to chrome cleaning issues.
Thanks!
Sent from my SGH-I337M using Tapatalk
2008 Kingpin Premium
Newfoundland,
Canada
deepstuff is offline
post #2 of 58 (permalink) Old 09-28-2017, 10:58 AM
BBob is online now
post #3 of 58 (permalink) Old 09-28-2017, 12:55 PM
Get HH pads for the front and cheapies (GG if they have 'em) for the rear to help prevent lock-up and for more sensitive trail braking in tight curves.
post #4 of 58 (permalink) Old 09-28-2017, 01:01 PM
before you install pads lay a peace of 80 grit sandpaper on a flat surface. Now run the pads across them a few times. This will speed up the brake in period. Yes it takes a good 10 stops or more for pads to really stop you.
Remember front brake stops you rear brake slows you down but does not stop you in a critical situation
BBob and RICZ like this.
post #5 of 58 (permalink) Old 09-28-2017, 01:06 PM
After sanding, clean them off. If your old ones have a radiator plate on the backs, be sure to transfer them to the new ones. Clean off the discs with alcohol or brake cleaner. If the brake fluid is 2 years old, change it and bleed the system.
TNXR likes this.
post #6 of 58 (permalink) Old 09-29-2017, 12:03 AM
whooshbang's Avatar
Thanks!
Ceramic pads will vastly reduce the horrible black dust you get from standard pads. look for ceramic blend pads, organic pads made of blended fibers that can consist of a combination of Kevlar, synthetic glass, carbon and aramid fibers.
EBC Redstuff pads are ideal if you can get them or a semi-sintered or organic pad. I believe fully sintered pads will produce more brake dust due to the ratios of steel fibres in the pad.
https://ebcbrakesdirect.com/motorcycle/victory
2015 Victory Judge
whooshbang is offline
post #7 of 58 (permalink) Old 09-29-2017, 08:52 AM
Motorbikerx's Avatar
I like Lyndalls though anthing is better than stock
GatorJoe likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 58 (permalink) Old 09-29-2017, 10:33 AM
depot picker's Avatar
I use EBC HH front and rear. I wipe the rotors.
depot picker is offline
post #9 of 58 (permalink) Old 09-29-2017, 11:03 AM
skullsessions's Avatar
....Remember front brake stops you rear brake slows you down but does not stop you in a critical situation
More than once I've seen you give this advice when people ask about brakes.
It's false...and dangerous advice to be handing out.
BP6666VR likes this.
2013 Cross Country (Houston/Katy Texas)
People think I am too patronizing. (That means I treat them as if they're stupid.)
skullsessions is offline
post #10 of 58 (permalink) Old 09-29-2017, 11:18 AM
Interestingly, my XR came with HH rear pads and they were grabby - too easy to lock the wheel. The original fronts were best described as "wooden." An odd combination to send a bike out into the world with.
