Gas tank swap issue - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 12-02-2017, 08:35 PM Thread Starter
cvsisinthehouse's Avatar
Default Gas tank swap issue
I bought this 2005 (the one with the big hole) tank for my severely dented 2009 Hammer S. Spent 2 weeks painting it, then today noticed its totally different underneath. Is this possible to use? thanks.
cvsisinthehouse is offline
post #2 of 6 (permalink) Old 12-02-2017, 08:49 PM
DirtyDan's Avatar
I would say no right off the bat but there are those with way more knowledge on this subject than I. Good luck.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #3 of 6 (permalink) Old 12-02-2017, 09:09 PM
VicVisionBulldog's Avatar
Do the fuel lines and pump connection plug connect?
If they do and the mounting holes are the same I don't see why it wouldn't. The pump just needs power and the bike fuel. You may need to redo some of the connections if they aren't the same but I'm sure it's possible.
VVB
13 Vision Tour - PCV, Top Filter, Stage 1 Pipes, TW @ +4, Metz 888s
VicVisionBulldog is offline
post #4 of 6 (permalink) Old 12-03-2017, 12:18 AM Thread Starter
It didnt come with any fuel lines or wiring. I will ask the people I bought it from and also see what is under this black grate. Thanks.
post #5 of 6 (permalink) Old 12-03-2017, 12:41 AM
Motorbikerx's Avatar
Doubt it..unless you got the fuel pump that fits the big round hole....
The black grate you talk of on yours has the fuel pump on the inside of it.
Must be a real bummer man...always best to check fit of parts prior to painting.
I'm sure most of us that do our own work have been stung by a similar occurance ourselves in the past...rest assured you're not alone.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 6 (permalink) Old 12-03-2017, 01:03 AM
I'm sorry I was thinking of it backwards. I thought the top tank is what you were trying to put on.
Without the pump to match that tank I don't believe the pump from your original tank is going to work.
VVB
