Hi folks, while we still can and before it becomes a major issue, I'm hoping with everyones help we can compile the basic info on what size belt fits the various years and models. Here is what I have so far so if you can add to this for us in the future and others more importantly; it would be a great help. Maybe one of the mods can make it a sticky for future reference.
Belts are one of those items we can't simply have a machinist make or modify to fit.
Model Years #Teeth Width Pitch
Vision/X-Bikes All 154T 28mm 14mm OEM # BELT, DRIVE, 154T, 28MM 3211107
Current source as of 12/24/17 click HERE.
SC, TC, Etc Pre-2003 135T 1.5” 14mm OEM # 3211085
BDL Polychain Final Drive Belt 1.5" 14mmP 135T #PC-135-1 1/2 Harley Davidson - Found on ebay; made for HD fits pre-2003 Vic's.
Note: TC's from 2002 - 2006 use a 142 tooth belt. It's the same belt used on the 03-05 steel frame bikes listed below. The wheelbase is a couple inches longer than the SC's.
All Steel Frame 03-05 142T 35mm/1-3/8"/1.42" 14mm pitch OEM # 3211088
No alternate source at this time. Will update when there is one.
All Steel Frame 06-2017 147T 28mm 14mmP Plus 05 Hammer and JP. OEM# 3211102
2006 and up steel frames are 147 teeth. Include 05 Hammer and JP.
If the guys who have a 147 tooth belt use a 31 tooth front pulley (Under Drive from Conquest Customs) then a Buell 1125R belt will work, part #G0500.1AMG (Thanks H_C)
Some oil filter and oil info provided by RoteBaron
Oil Filter
20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket, 3.5" long. These all use synthetic media and accordion wrap.
• * Purolator ML 16851,
• WIX 51356 or 51356XP , $7.99/O’Reilly’s
• Mobil 1 M1-110, $12.__/Advance
• Bosch 3323, $13.__/Advance
• NAPA PFL 41365
• Super-Tech ST7317, $2
• Polaris 3084963 - $8.54
• K & N – 198 - $13.99
Oil filter cross reference for Wix 51356<Click Here
Motor Oil - 20W - 40
• Rotella T6 5W-40, synthetic, $23.99/Advance
• Lucas Synthetic SAE 20W-50 - $
• Mobil 1 V-Twin 20W-50 synthetic, $9.49
• Mobil 1 Racing 4T 10W-40 was previously known as Mobil 1 MX4T 10W-40 - $11.99
• Mobil1 5W40 Turbo Diesel Oil? Not enough information
• Amsoil 20W-50 synthetic, $10.90
• Castrol V-Twin Power RS Semi-Synthetic 20W-50 - (#8178) - $8.99
• Castrol ACT-EVO X-TRA 4T Semi-Synthetic (#558754) – 1 gal $23.99
• Rotella T5 semi-synthetic (silver jug-4qts) - $16
• Victory Semi-Synthetic 20W-40
Oil Drain Plug: M12 x 1.5mm
Oil Drain Plug Washers: 12mm ID x 19mm OD x 1.3mm thick - copper crush washers
p.s Same washer that is used on Toyota R22
NAPA - bag of 25 Price $6.00
http://www.conquestcustoms.com-Drain Plug Crush Washer REFILL KIT - Dozen - Price $6.00
http://buywitchdoctors.com-5 Pack Oil Drain Plug Washers - Item # DP-WASH - Price $ 4.25
Magnetic Drain Plugs for Indian/Victory Motorcycles - $34.95. (high power magnet)
Air Filter
POLARIS VICTORY - Part # 7080858 - $59.99
K&N - Part # PL-1500 - $52.95
*Stay away from the Purolator Pure One oil filter. It is a very good filter but it may be too restrictive for the Victory engine for oil flow. Vic runs at Higher Oil pressure than the puro was designed for.
X-Bike Side Cover Grommets: NAPA part# NW784633
Clutch Lever Pin: Yamaha P/N 3GM-26455-00. They fit the first generation Venture.
NGK spark plugs p/n 3481
Fork Seals
X-Bikes: Size is 43x55x9.5mm and are available through Witchdoctor's or by size from ATVparts.com.
Vegas style forks: Size: 43x55.15x9.5/10mm Witchdoctors. Also available at the ATVparts place listed above. Also; allballsracing.com
Cam install Instructions for X-Bikes: https://www.sscycle.com/docs/defaul...for-victory-cross-country-models.pdf?sfvrsn=2
Oil Filter
• NAPA PFL 41365
Air Filter
Fork Seals
