Fastner Torque values - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 12 (permalink) Old 01-24-2018, 01:20 PM Thread Starter
Default Fastner Torque values
The 500 mile initial service calls for re-torquing fasteners. Is there a list of which fasteners should be checked, and their values?
2016 Hammer S...stock
Spacecoast is offline
post #2 of 12 (permalink) Old 01-24-2018, 05:38 PM
Motorbikerx's Avatar
No ...but re torque means re torque, not just check.
Proper re torque involes slackening off the fastener before re torquing.
Dont use a torque wrench in reverse either itll hurt it.
Oh and dont confuse inch pounds with foot pounds or Newton metres.
Personally Id leave the first service to the dealer, most of us wouldve bargained that into the deal at point of sale.
Hopefully you have a dealer you can trust.
visionjohnny likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 12 (permalink) Old 01-24-2018, 06:23 PM
gamewarden's Avatar
Shop manual has all the torque values which can be had through a member Bbob.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #4 of 12 (permalink) Old 01-24-2018, 06:36 PM
They didn't change much over the years so find the closest to your year and download it for free.
post #5 of 12 (permalink) Old 01-24-2018, 06:41 PM Thread Starter
I appreciate your advice, but I would never slack off bolts only to re-torque them, especially not knowing if some have thread lock. The factory should have properly torqued everything, and the real goal is to ensure nothing is coming loose. Usually axle bolts, pinch bolts, swing-arm, engine mount points, and foot-peg brackets are the prime target. And yeah, I don't ever fully trust any dealer since I have no history to go by except the initial sale and internet horror stories. I have all the tools and the experience, so hopefully I can get some values. I plan on doing all oil changes since most would never even prime the filter prior to install (and yes, you can almost completely fill a side mounted filter and get it installed without losing any oil) and I have the tool and stand for adjusting the drive belt.
post #6 of 12 (permalink) Old 01-24-2018, 06:42 PM Thread Starter
Thanks...can you provide a link, or is there a thread somewhere? Oh...I see a link on your signature.
post #7 of 12 (permalink) Old 01-24-2018, 06:52 PM
Fair enough but you did say RE TORQUE
youre not re torquing you are checking.
Theres a big difference.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #8 of 12 (permalink) Old 01-24-2018, 06:54 PM Thread Starter
True....very true.
post #9 of 12 (permalink) Old 01-24-2018, 09:02 PM
depot picker's Avatar
Shop manual, which can be had through a member Bbob, has all the torque values.
depot picker is offline
post #10 of 12 (permalink) Old 01-24-2018, 09:34 PM
djh3's Avatar
We use to do "nut and bolt check" on the race car. In the USAF we did a torque check on fasteners. Basically the same operation. Put a wrench on it and see if it moves, dont try to make it move. If has a torque value set the wrench and get after it.
2013 XCT added Jan 2015
djh3 is offline
