117 build cam degree'ing question - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By Motorbikerx
post #1 of 2 (permalink) Old 02-08-2018, 11:09 PM Thread Starter
nvr_fst_enuf's Avatar
Default 117 build cam degree'ing question
I am doing a basement 117 build. Had my heads CNC ported, chambers blended, radius valve job, and surfaced .015. 530+ minutes of labor...LOL
So my question is since they have been decked and the valves are closer to the piston, how should I go about figuring how many degree's to compensate the cams??
Can't wait to get her back together and hear her perrrrrrrrrr!!
Thanks in advance!
Brian
Brian
2012 Hammer
Basement built, 11:1 - 117 Big Bore, CNC ported heads, CNC valve job, .015 deck, .495 cams, 801 MotoWorx Maximus tune, Torque Tubes, Barnett cables, Barnett Scorpion clutch, RPW Slash Pipes, Pro-Taper bars, Penske Shock. 124hp/146tq
2011 CCT
LRS windshield, D&D Slips, K&N Filter, HID lights, Maximus, Forged lowers
nvr_fst_enuf is offline
post #2 of 2 (permalink) Old 02-09-2018, 03:35 AM
Motorbikerx's Avatar
Thanks in advance!
Brian
Id be giving Kevinx at Southern Motorworx a call.
Im no expert but the guys that did my big bore resleeve top and tailed some off the barrels to square everyyhing up and then dummy assembled it with soft valve springs and wound it over by hand to check piston to valve clearance with plasticine on top of the pistons.
Everything cleared on mine.
Lloyd supplied extra base gaskets for adding clearance.
Pretty sure they doubled up the base gaskets on mine.
Give Kevin a call mate, he was happy to guide me through some stages of my build.
Yours is gonna have some grunt!
Chattanooga Mark likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
