Does a Magnum Really need the Barnett Clutch Cable? - Victory Forums - Victory Motorcycle Forum
 16Likes
post #1 of 23 (permalink) Old 02-26-2018, 06:34 PM Thread Starter
Bueller's Avatar
Question Does a Magnum Really need the Barnett Clutch Cable?
Witchdoctors has those Barnett clutch cables saying they reduce clutch effort. I dont have a major problem with the clutch, but I want to ask if we have any proof that says the stock 2016 cable 1. Not plastic coated so the Barnett is better. 2. Is poorly made and improved with a Barnett Clutch cable. 3. Requires a lot more effort than the Barnett. Barnett claim is 40% reduction in pull force. WTF? its 2016 and is this true?
16 Magnum Midwest USA
Bueller is offline
post #2 of 23 (permalink) Old 02-26-2018, 06:49 PM
BP6666VR's Avatar
When i was reading about 10 forum members breaking the stock cable on the road... i decided to replace it with that barnet cable ... I did not notice that much difference, but i replaced it coz it lasts MUCH longer than stock, and now i carry the stock one as a spare in my CCT ....
Maybe in the next few years they will be difficult to find ?
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 23 (permalink) Old 02-26-2018, 07:30 PM
Andre may not have noticed much difference on his Jackpot, but when I put a Barnett cable on my XR I sure noticed a much lighter and smoother pull. That cable, combined with an EZ-Pull and my clutch is like that on a 250cc bike. Which is much appreciated by this old rider.
visionjohnny and BP6666VR like this.
post #4 of 23 (permalink) Old 02-26-2018, 07:46 PM
depot picker's Avatar
I've had 2 original and 1 Barnett. There may be a minor difference. Lubricate the ends and any cable will work better. I'd stay away from the EZ clutch unless you know your way around the shop.
RICZ and visionjohnny like this.
depot picker is offline
post #5 of 23 (permalink) Old 02-26-2018, 08:01 PM
There's a lot of truth in that last sentence. Not only is free play a bit dicey, but possible, but you also have to do some clever shimming to align the cable with the sheath at the bottom end so it comes out straight. You also have to make sure there are no rough spots on the EZ-Pull that will chafe the cable. Should do that at the handlebar lever too.
post #6 of 23 (permalink) Old 02-27-2018, 03:29 AM Thread Starter
Bueller's Avatar
40 percent is a big diff. BIG claim to make with the barnett cable. Maybe someday we will find evidence of this magic.
depot picker likes this.
Bueller is offline
post #7 of 23 (permalink) Old 02-27-2018, 05:38 AM
Motorbikerx's Avatar
Wheres it say 40%?
I fitted a Barnett cable after my rebore and cams as I also fitted a Barnett Scorpion clutch and wanted as much as possible in my favour with old arthritic hands.
The Barnett Scorpion was overkill so I went back to a Victory clutch with Barnett spring and cover plate which is still quite heavy.
I honestly dont think theres any difference in effort between stock cable and Barnett.
The real reason I went with Barnett cable it was on special at the time and it was 6" over which was good with my Burleigh Bars but bottom line the Barnett is stronger and better designed the way the barrel ends pivot and dont stress the cable.
The stock cable has inherent weak points in its design and even though my stocker lasted 60,000 miles as Im critical about maintenance of the cable ends which is crucial with the stock cable.
Im about to go back to the Victory green spring and stock coverplate soon and with that setup I can use the EZ Clutch ad all will be sweet as Im only on 115hp 123 tq and stock clutch is ok with those numbers.
Only then can I give a true opinion onthe feel of the Barnett cable.
Bottom line its less liable to break.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 23 (permalink) Old 02-27-2018, 06:48 AM Thread Starter
Bueller's Avatar
40% less effort https://buywitchdoctors.com/p/599824...-inch-sc-2637/ and hell this cable is 6 inchs longer.
Bueller is offline
post #9 of 23 (permalink) Old 02-27-2018, 07:44 AM
Thats a throttle cable..
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #10 of 23 (permalink) Old 02-27-2018, 11:20 AM
Blowndodge's Avatar
I still have the stock clutch cable on and have had an EZ clutch on for over 40K miles. Both ends of the cable look fine, no fraying or wear. Clutch is fine with 51K miles so far. If you don't know how to adjust the free play in a clutch cable then you'd be better served with a hydraulic clutch. I think with the substantial reduced effort on the clutch with the EZ clutch cover my cable should last substantially longer.
RICZ and Motorbikerx like this.
2013 Victory XCT. Lakewood, CA
Russell Day Long Saddle.
7Jurock 14" tinted flip shield
Unplugged O2 sensors.
Stage one filter.
14" replacement ant.
Drag Specialties highway pegs.
Custom Pin-striping.
Blowndodge is offline
