Draining the battery - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 13 (permalink) Old 02-28-2018, 10:17 AM Thread Starter
Default Draining the battery
I have had a issue with what I believe is the radio on my 2013 X-Country. I ride with music and have an I-Pod hooked up. I rode one day last month and not knowing when the next nice day would show up I shut off the I-Pod(which I never do in the summer) 3 days later I went to ride to work and the battery was completely drained. After I charged the battery and started the bike the radio would not recognize the I-Pod but is charging it. And still the battery is not draining(I have not left the I-Pod on or plugged in). Suggestions?
the.oleman is offline
post #2 of 13 (permalink) Old 02-28-2018, 10:41 AM
Are you talking about the iPod battery or the bike battery?
post #3 of 13 (permalink) Old 02-28-2018, 10:52 AM
kezzy39's Avatar
I have been having the same issue with my 2014 CC. intermittent though. iPhone charges but the radio does not recognize the IPhone sometimes. Bike battery not draining.
2014 Cross Country. Stage 1 Exhaust Upgrade. LED Headlight. Keyless Ignition. Victory Chrome Bling.Winnipeg Manitoba Canada.
kezzy39 is offline
post #4 of 13 (permalink) Old 02-28-2018, 10:59 AM Thread Starter
The motorcycle battery sir.
post #5 of 13 (permalink) Old 02-28-2018, 11:10 AM
Odd. I have left my iPod in the bike and it hasn't drained the battery. Is it original? Do you have any aftermarket USB ports installed? They will drain a battery even if nothing is plugged in. How's the starting performance - does it still turn over strong? I'm wondering if the battery is on its way out...
post #6 of 13 (permalink) Old 02-28-2018, 01:00 PM
Are the battery terminals tight? They do tend to loosen. How old is the battery? What does the voltage read at when the bike is sitting?
post #7 of 13 (permalink) Old 02-28-2018, 02:44 PM Thread Starter
It starts great now. I have a lithium battery I put in last summer. This only happened once, the only time I turned off the I-Pod while still plugged in. Now the radio will not even recognize the I-Pod and I get the green battery sign showing charging.
post #8 of 13 (permalink) Old 02-28-2018, 02:46 PM Thread Starter
Yes the battery terminal are tight. I find what happened very strange. It only happened ONCE.
post #9 of 13 (permalink) Old 02-28-2018, 03:24 PM
I thought I read where the Vic's didn't like lithium batteries by someone here. Don't know, I don't have first-hand experience...
post #10 of 13 (permalink) Old 02-28-2018, 03:35 PM
I was seriously considering a Lithium battery, but after doing my due diligence and reading up on other that the mfr's hype, I learned there are a lot of things not to like about them. Such as; If your engine doesn't start on the first try, there may not be a second try left in the battery. There are more negatives, but that one was too much for me.
