How to lube throttle cable ends? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-02-2013, 11:26 AM Thread Starter
Default How to lube throttle cable ends?
So, the book says to lube the throttle cable ends only. But for the life of me, I can't figure out how to get to the cable ends at the throttle body under the tank. I also assume no lube is needed up by the throttle grip. Anyone do this and could you provide some help?
2013 Boardwalk in White
2012 Cross Roads (Retired)
jcanrun is offline
post #2 of 6 (permalink) Old 04-02-2013, 11:31 AM
jackwithcorona's Avatar
The cable ends under the tank are not that hard to access. as daunting as it may sound, you can lift the tank to get to them easier. You just take off the two side panels and remove the seat by two allen bolts on either side, and then the back of the tank has a bolt under the front of the seat. loose the two bolts under those plastic black straps by the forks at the front of the tank and you can lift the tank up enough to access the throttle cables. you can search for a better detailed step by step method of how to remove the tank on these forums, and its really easy. i had to reroute the throttle cables on my bike when I put the highball bars on.
good luck.
2006 Suzuki SV650 (Traded)
2012 Victory Vegas 8-Ball (Traded)
2014 Victory Cross Country
1985 Harley XLH
jackwithcorona is offline
post #3 of 6 (permalink) Old 04-02-2013, 12:20 PM
half_crazy's Avatar
I suggest silicone brake grease, that's what I use.
2006 Victory Kingpin
half_crazy is offline
post #4 of 6 (permalink) Old 04-02-2013, 03:54 PM
depot picker's Avatar
Be carefull with the tank. Best to read the procedure somewhere first.
depot picker is offline
post #5 of 6 (permalink) Old 04-03-2013, 01:02 PM
why not pull a wedge and with some kind a spray like wd40 give it a shot or two.
You will not make a mess unless you drowned it.
You don't half to do it very often
post #6 of 6 (permalink) Old 04-03-2013, 01:27 PM
NJ8BALL's Avatar
Wd40 well wear off quick. Perhaps a shot of white lithium in a pinch
'09 Kingpin 8-Ball...Sanded chrome exhaust, Stage 1 slipons, VFCIII, Lloyds IAV, Stonny's 27" sissybar, Edge bags with ghost brackets,Kuryakyn black ISO grips,
http://www.bluebeardimagery.com/
http://blue-beard-imagery.artistwebsites.com/
Photo equip: Canon 60D, Canon 55-250is, Canon 18-55, Canon 70-200f4,Tamron SP10-24
NJ8BALL is offline
