Rear brake issue...ABS? - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 12 (permalink) Old 04-05-2018, 10:00 AM Thread Starter
spyshot's Avatar
Default Rear brake issue...ABS?
I thought I would post an update on the brake issue and maybe this will help someone else out.
Installed new bearings on the rear wheel trying to fix hum/howl issue. (no, it did not solve that).
New problem, took bike out for test. ABS light stays on.
Bring bike in garage. Adjusted ABS sensor by removing 1 spacer to bring air gap into spec. Gap was 1.6mm. Now it is 1.1mm.
Take bike out for test, ABS light goes out. Cool!
New problem, rear pedal has extra resistance when initially pressing (feels like something is preventing me from pushing the pedal down far enough), then resistance goes away and brakes operate okay. Push rear brake again, same thing. However this doesn't seam to happen at lower speeds but happens everytime I push the pedal at normal-high speeds.
After a few miles the ABS light comes back on, which I assume disables that ABS system, because the resistance in the brake pedal is gone and brakes seam to function as normal.
So apparently there is still something going on in the ABS that is causing the funny sensation in the rear brake pedal.
I think I'm going to take it to a dealer. I'm one hour away, but I'm getting a bit tired of all this.
2012 Pearl White Cross Country Tour
D&D Pipes
Lloydz ATS
Lloydz Filter
spyshot is offline
post #2 of 12 (permalink) Old 04-05-2018, 11:58 AM
GatorJoe's Avatar
Had a similar Problem on my 2012 XC and let KevinX take care of it .. Rather than Pull what hair I have Left out and he is only 20 miles away .. Hopefully someone else can chime in with a solution ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #3 of 12 (permalink) Old 04-05-2018, 12:22 PM
NOEMTZ's Avatar
Confirm Pads are set or seated in correctly right possibly causing friction. Also the clip that spring loads pads may have moved.
ABS could be sensor wire not run correctly, wire pinched or simply going out. See it all the time.
wspollack likes this.
www.noemtz.com
“I DON’T PICK SIDES, GO WITH THE FLOW, OR PUT UP WITH BULLSHIT.
I RELY SOLELY ON MYSELF, BEAUSE I HAVE MY OWN BACK. NOEMTZ - 2010”
NOEMTZ is offline
post #4 of 12 (permalink) Old 04-05-2018, 01:41 PM Thread Starter
spyshot's Avatar
Checked fuses. Checked gaps. Cleaned sensors.
Maybe i will replace sensor before taking to dealer.
D&D Pipes
Lloydz ATS
Lloydz Filter
spyshot is offline
post #5 of 12 (permalink) Old 04-05-2018, 07:41 PM
What did KevinX have to do to correct your ABS issue?
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #6 of 12 (permalink) Old 04-06-2018, 04:48 AM
GatorJoe's Avatar
Rear Sensor ...
GatorJoe is offline
post #7 of 12 (permalink) Old 04-06-2018, 05:42 AM
rainman123's Avatar
Did you check your abs relay
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #8 of 12 (permalink) Old 04-06-2018, 06:22 AM
Location: Cairns area. Far North Queensland, Australia.
I'll put my money on it being a bad sensor.
2014 XCT in Bronze Mist
2000 H-D Road King
2003 Suzuki SV1000
2003 Aprilia SL1000R
1977 Honda CB750K7
Plus a few others in the shed
ozpacman is offline
post #9 of 12 (permalink) Old 04-06-2018, 06:46 AM Thread Starter
spyshot's Avatar
Is that the same thing as a rear sensor?
D&D Pipes
Lloydz ATS
Lloydz Filter
spyshot is offline
post #10 of 12 (permalink) Old 04-06-2018, 06:54 PM
rainman123's Avatar
No the relay is under the right side of the rear fender
2012 crossroad
73 sportster sold
06 rocket3 classic
