Removing rear wheel on kingpin, pipes in the way. - Victory Forums - Victory Motorcycle Forum
 4Likes
  • 1 Post By RICZ
  • 1 Post By RICZ
  • 2 Post By visionjohnny
post #1 of 10 (permalink) Old 05-01-2018, 08:58 AM Thread Starter
bbqjoe's Avatar
Default Removing rear wheel on kingpin, pipes in the way.
I have the stage one pipes on my '05 KP.
The top one is in the way of removing the axle bolt.
Do these pipes come apart, as in pulling the back half off or something, or does the whole exhaust need to come off.
Sorry, I've never done this before.
Thanks.
Joe
05 Victory Kingpin
06 Yamaha Vstar 650
09 Suzuki Boulevard C50T Pics here>>>http://i.imgur.com/WvEEFDQ.jpg?1
1 Woman
2 Jack Russells
2 Baja mini bikes
And a Les Paul
Teach a kid about bikes, and he'll never have money for bad habits.
bbqjoe is offline
post #2 of 10 (permalink) Old 05-01-2018, 11:29 AM
I was hoping a KP owner would chime in before now and assuming you want an answer soon, I will submit this...
Assuming the KP has the same rear suspension as the Cross bikes, you lift the bike - wheels off the ground - place a jack under the rear wheel ( I use a platform scissors jack) unweight the rear wheel enough to be able to remove the two bolts connecting the rear suspension to the swing arms and then lower the rear wheel. The axle should clear the mufflers.
Rear wheel removal should be in your manual.
VicVisionBulldog likes this.
post #3 of 10 (permalink) Old 05-01-2018, 11:33 AM
VicVisionBulldog's Avatar
I'm thinking the same.
VVB
13 Vision Tour - PCV, Top Filter, Stage 1 Pipes, TW @ +4, Metz 888s
VicVisionBulldog is offline
post #4 of 10 (permalink) Old 05-01-2018, 11:37 AM Thread Starter
bbqjoe's Avatar
Thanks. I'll investigate.
On the other hand, I think I'll let a shop do my tire change.
05 Victory Kingpin
06 Yamaha Vstar 650
1 Woman
2 Jack Russells
2 Baja mini bikes
And a Les Paul
bbqjoe is offline
post #5 of 10 (permalink) Old 05-01-2018, 11:49 AM
I have a problem...I do not trust others with tools and my things. In my over four decades of being a repairman, I have seen way too much ham fisted work done by so-called professionals charging way too much.
I don't have tire changing equipment, so I take my wheels to my tire guy to have new ones mounted. I remove the rear sprocket so it won't get bunged up - again. Lesson learned.
adamnorthup likes this.
post #6 of 10 (permalink) Old 05-01-2018, 12:15 PM Thread Starter
bbqjoe's Avatar
Well it's a Vic/Indian shop, so I'm putting my faith in them.
If I had a garage, I might think things differently.
Thanks for your responses.
05 Victory Kingpin
06 Yamaha Vstar 650
1 Woman
2 Jack Russells
2 Baja mini bikes
And a Les Paul
bbqjoe is offline
post #7 of 10 (permalink) Old 05-01-2018, 12:22 PM
Have them put the axle nut on the left side of the bike. Then you can pull the axle out the left side and pipes will not matter. Once the nut is loose you can slide the locking tab out on the right side
vindex1963 and adamnorthup like this.
post #8 of 10 (permalink) Old 05-01-2018, 12:36 PM Thread Starter
bbqjoe's Avatar
Brilliant!
I'll do that.
05 Victory Kingpin
06 Yamaha Vstar 650
1 Woman
2 Jack Russells
2 Baja mini bikes
And a Les Paul
bbqjoe is offline
post #9 of 10 (permalink) Old 05-01-2018, 01:37 PM
WeekendRider's Avatar
NO, NO, NO, NO!
For the sake of all that is holy, don't let @half_crazy see this!
Please review the following:
Rear Tire Removal | Page 2 | Victory Motorcycles: Motorcycle Forums
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #10 of 10 (permalink) Old 05-01-2018, 01:46 PM
HC eventually posted the instructions from the (his words) f**king manual...
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
