Vegas Passenger Peg Bracket Dimensions - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 04-03-2013, 05:56 PM Thread Starter
82crawler's Avatar
Default Vegas Passenger Peg Bracket Dimensions
As an avid fabricator, I am looking to build my own passenger peg brackets but haven't been able to look at any up-close. Would anyone mind taking a picture or two of how/where they mount and possibly a dimension or two for how far the brackets stick out from the mounting hole surface?
Thanks!
2012 Vegas 8-Ball
82crawler is offline
post #2 of 8 (permalink) Old 04-03-2013, 10:54 PM
VictoryMuscle's Avatar
i have an 05 vegas are they all the same? ill pull mine off and make you a drawing if theyll work
2005 Victory Vegas
Ness Signature Series
Stage 1 kit
VictoryMuscle is offline
post #3 of 8 (permalink) Old 04-04-2013, 12:33 AM
I'll be ordering a set next week (after get paid from second job). I'll try to get pics and measurements before install. I'll be ordering them through a shop (same place that will be installing them), so I'll have to catch them before they put them on the bike.
2012 Cross Country Tour (Black)
Bought brand spanking new with 1 mile on odometer!
2012 Vegas 8-Ball (used, but only 782 miles on it!!)
2009 Hyosung GV250 for daily commute (Traded for the Vegas 8-Ball)
1981 Kawasaki 440LTD (First bike ever owned)
V-Man is offline
post #4 of 8 (permalink) Old 04-04-2013, 08:18 AM Thread Starter
82crawler's Avatar
I would assume they'd be the same for an 05? I would greatly appreciate either of you getting that info!
2012 Vegas 8-Ball
post #5 of 8 (permalink) Old 04-04-2013, 10:19 PM
I was planning on doing this for my 2007 Vegas. I don't want to run with the rear pegs, but the saddle bag bracket uses the same mount. So, I have no choice, but the leave them on.
I was going to carve something out of 3/4 aluminum bar stock. Here are some pictures and dimensions.
Hope is works out for you.
Ernie
efranzen is offline
post #6 of 8 (permalink) Old 04-04-2013, 10:36 PM
Forgot to add the thickness. It's 3/4" from bottom pad to saddlebag mounting pad.
Ernie
efranzen is offline
post #7 of 8 (permalink) Old 08-01-2013, 10:03 PM
BackInBlack44's Avatar
Im def gonna try this. Thanks
BackInBlack44 is offline
post #8 of 8 (permalink) Old 06-14-2014, 10:01 PM
Default Finished Peg Delete Brackets
I gave myself a Fathers Day present, by finally finishing the brackets to be able to remove the rear peg brackets while still using saddle bags.
I used a chuck of 3/4 x 1-1/2 aluminum and used a varity of saws, files and sandpaper to mold these to fit.
Took several hours of work and funny, as so little of it shows when on the bike.
Ernie
efranzen is offline
