Battery repair - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By Chattanooga Mark
post #1 of 8 (permalink) Old 05-16-2018, 09:54 AM Thread Starter
Default Battery repair
Does anyone know if a damaged battery post can be repaired?
2013 Cross Country
131k miles as of 5/14/2018
SF Bay Area, California
Power Commander V
Bassani Slip Ons
HiFlow Air Filter
Lloyds Cams
Heads ported and dyno’d by Rhom Performance Machines, Yuba City, Ca.
Second Dyno by RC Cycles, Hayward Ca. 120hp/121tq
2k watts rms driving 16 speakers
Tgranted is offline
post #2 of 8 (permalink) Old 05-16-2018, 10:04 AM
Is it just bent at the top and maybe part of the exposed post is torn or has the post been torn loose from the plates/bus inside the battery? If the latter, then it is game over for that battery. If the former, I think you can continue to use it. Just make sure to support the post with one tool while tightening the terminal screws.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #3 of 8 (permalink) Old 05-16-2018, 10:28 AM
Honda East Toledo's Avatar
That get dropped? You got lucky if all that happened was it got bent. Seen them look like that before but then be broke inside the case, is the post still solid or does it move at all?
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #4 of 8 (permalink) Old 05-16-2018, 11:19 AM Thread Starter
The post is still solid and I have no charging issues. I'm running 2k watts rms pushing 16 speakers. I probably wore the terminal down from the constant connecting and disconnecting while installing my audio.
2013 Cross Country
Power Commander V
Bassani Slip Ons
HiFlow Air Filter
Lloyds Cams
Tgranted is offline
post #5 of 8 (permalink) Old 05-16-2018, 01:22 PM
screw a 10 mm allen stud into the post then jb weld the hell out of it. Once the jb has dried then hook up cables and put a nut on the stud using the allen wrench to hold stud in place.
Or long as its a Drag Spec battery you might be able to get it warrantied. There pretty good about that
post #6 of 8 (permalink) Old 05-16-2018, 01:38 PM
The battery from Batteries+ has two mounting threads per post - one on the top and one in front. I use the top for the cables and the fronts for accessories.
Sixteen speakers?!? You have a very different idea of what riding is about than I do. This should help you battery situation - put it in the top trunk...
https://www.harborfreight.com/engine...enerators.html
post #7 of 8 (permalink) Old 05-16-2018, 01:46 PM Thread Starter
Thanks but my trunk is the only cargo space I have lol. I'll check out the other batteries
2013 Cross Country
Power Commander V
Bassani Slip Ons
HiFlow Air Filter
Lloyds Cams
Tgranted is offline
post #8 of 8 (permalink) Old 05-16-2018, 09:08 PM
From looking at the pictures it looks to be twisted to the right as in being (over) tightened. How did I do?
If it were me, I'd replace the battery as I wouldn't trust that compromised terminal. These bikes are voltage and battery terminal sensitive to begin with. So, for peace of mind, consider replacing it.
RICZ likes this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
