1st oil change - Victory Forums - Victory Motorcycle Forum
 5Likes
  • 2 Post By TNXR
  • 1 Post By IndyVictory
  • 1 Post By BP6666VR
  • 1 Post By vindex1963
post #1 of 10 (permalink) Old 05-18-2018, 05:07 PM Thread Starter
Default 1st oil change
Going with the Castrol actevo 20-50
Done and done
Sent from my SM-G955U using Tapatalk
White 2016 CC
Bone stock
Vancouver WA
xxholdxx is offline
post #2 of 10 (permalink) Old 05-18-2018, 06:21 PM
.................................................. .............crickets
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #3 of 10 (permalink) Old 05-18-2018, 09:06 PM
Bueller's Avatar
Would have been cool to see the Blackstone labs oil report.
16 Magnum Midwest USA
Bueller is offline
post #4 of 10 (permalink) Old 05-19-2018, 05:09 AM
TNXR's Avatar
Good for you OP! What brand of oil and filter you choose does not really matter, just as long as you change the oil at or before the mileage/time the manual says to.
2011 Cross Roads Sunset Red
TNXR is offline
post #5 of 10 (permalink) Old 05-19-2018, 05:42 AM
Wow someone who speaks the truth. Oil is the oldest most frequent pointless debate in the motorcycle community.
Chattanooga Mark likes this.
Red 2012 Cross Country Tour
Polk 522, Nautilus air horn, 17" rubber antenna, knob saddlebag release, black tri-ovals, sabertooth saddlebag lights, Madstad windshield, many parts chrome to black.
post #6 of 10 (permalink) Old 05-19-2018, 09:04 AM
BP6666VR's Avatar
Actually i have been doing oil lab tests sins the beginning of my bike and it is a FACT that the oil starts deteriorating at 7000 kilometers,
BUT it is really hot here, never ride longer then 10 minuts in 1 gear, etc etc ...
I agree, as long as there is no clutch slippage and you change your oil at lets say between 6 & 7 k kilometers then the engine is fine,
But please use a magnetic drain plug ...
Andre using TaPaTaLk
visionjohnny likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
post #7 of 10 (permalink) Old 05-19-2018, 05:19 PM Thread Starter
Yeah I'm going to get 1.
I went with the heavier weight oil for summer ill switch back I. The fall.
The service manual calls for 20 40 or 15 60 so I split the middle lol
White 2016 CC
Bone stock
Vancouver WA
xxholdxx is offline
post #8 of 10 (permalink) Old 05-20-2018, 12:29 AM
vindex1963's Avatar
Name brand
Wet clutch compatible
BAM, good to go.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #9 of 10 (permalink) Old 05-20-2018, 11:06 AM
It is not OK to go to a higher viscosity oil. This is especially true in an engine like the 106 with has two oil systems; one for lubing and one for cooling. Orifices are sized for 40 weight, not a higher one, which will slow the flow and effect cooling.
Alternately, it is OK to use a lighter cold viscosity as it is thin only at startup and then begins to thicken as the engine warms. An oil such as Rotella T-6, with a 5W-40 weight has the advantage of circulating faster on cold starts and getting the lifters operating and quieter right off the bat.
So I can't go along with xxholdxx using a higher viscosity oil.
post #10 of 10 (permalink) Old 05-20-2018, 01:57 PM Thread Starter
The service manual specifically states you can use 15w-60 in the bike.
Victory Semi-Synthetic Oil Type 20W40 or 15W60 synthetic Engine Oil
That is pasted directly from the service manual
White 2016 CC
Bone stock
Vancouver WA
xxholdxx is offline
