Yes, O2 sensor question. - Victory Forums - Victory Motorcycle Forum
 17Likes
post #1 of 21 (permalink) Old 05-24-2018, 04:00 PM Thread Starter
Default Yes, O2 sensor question.
Is it really worth disconnecting the o2 sensors on my ‘16 Magnum?
I was planning on clipping 2 wires and leaving the heater circuit intact. Will this do anything? How bad will it affect Fuel mileage? I currently only get at minimum if about 215 miles(depending on wind and other environmental factors) .
2000 Yamaha VStar Classic (Current)
2013 Victory High Ball (R.I.P)
Alberta, Canada
Rootzee is offline
post #2 of 21 (permalink) Old 05-24-2018, 05:54 PM
doobliss's Avatar
Originally Posted by Rootzee View Post
Is it really worth disconnecting the o2 sensors on my 16 Magnum?
Model year '16 introduced the new 02 sensor wiring = If you unplug them, the "check engine" light comes on. I am unaware of a way around that, outside of a piggyback fuel controller or other tuning device. It's a bummer for sure.
'15 Gloss Titanium XC.
WOLO Low Tone Disc Horn
Tri-Oval Slip Ons
Black LED Headlight
Kingpin Metal Fork Guards
Ricz Lay Down Plate
Lloydz Timing Wheel & Throttle Ring
Shinhopples Grip Covers
12" Long Ride Shield
Bad Ace Billet Fork Mounted Air Deflector
Ness Signals; Amber front, Red rear
http://www.pure-gas.org/
"I leave the BUG CARNAGE on my screen , it adds character!"-LILMAGS500
doobliss is offline
post #3 of 21 (permalink) Old 05-24-2018, 07:00 PM
Don't butcher a new bike.
TNXR and Bueller like this.
2016 Hammer S...stock
Spacecoast is offline
post #4 of 21 (permalink) Old 05-25-2018, 05:21 AM
TNXR's Avatar
I have not touched the O2 sensors on my 2011 cross bike since I bought it new. I get around 40 mpg riding the twisty roads around here and I have more than enough power. 215 miles on a tank would be around 40 mpg if it is near empty and better if it is not.
2011 Cross Roads Sunset Red
TNXR is offline
post #5 of 21 (permalink) Old 05-25-2018, 01:26 PM
to prevent having a check engine light you need this. One per 02
half_crazy, broggyr and doobliss like this.
post #6 of 21 (permalink) Old 05-25-2018, 03:34 PM
RoteBaron's Avatar
I pulled the O2 connections on my 13 and added a timing wheel. Bike runs wayyyyy better.....
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg (Soon to go)
Victory High Flow Air Filter
Soon to tune with Maximus
2017 Highball - Suede Nuclear Sunset Orange
Xbow exhaust, High flow air filter, Lame stage 1 update (MEH)
RoteBaron is offline
post #7 of 21 (permalink) Old 05-26-2018, 07:55 AM
Bueller's Avatar
I have a new 16. The worse thing I could do is pull or plug those. When I get into the performance I will get a new 2018 Tuner and the 02 sensors will stay. Removing cats is also a dumb move to make on a Magnum or XC.
16 Magnum Midwest USA
Bueller is offline
post #8 of 21 (permalink) Old 05-26-2018, 06:24 PM
RoteBaron's Avatar
Default O2s
The bypass mentioned by VJ plus a Lloydz timing wheel and a higher flow air-filter is the poor man's (or cheap bastard's) tune up. The BEST choice is a maximus or a scab-over tuner and a dyno tune. Of course that's about a $1000....... Oh, and you NEED a 1/4 turn throttle ring....there are other "upgrades like cams and exhaust but.......$$$$.....LMYR
Long may you ride!
RB
post #9 of 21 (permalink) Old 06-15-2018, 03:22 AM
I'm the 'cheap bastard' that's trying to run without O2 sensors until I can get it in for a tune. I just installed the Dobeck bypasses and I'm still getting a check engine light. What gives?
2017 Gunner
Lloydz timing wheel +4
3rd Gear Intake
Dobeck O2 bypass (still have check engine light)
Brad Johnson is offline
post #10 of 21 (permalink) Old 06-15-2018, 06:37 AM
A 1/4 turn throttle ring isn't needed. It's a personal preference.
It doesn't increase performance, it just reduces the motion needed to operate the throttle. I had one, and ended up removing it. I like a little finer control of the throttle. The 1/4 ring made it a bit jumpier for me.
If you spend all day going WFO, it might be for you.
