Engine Loud Ticking Noise - Victory Forums - Victory Motorcycle Forum
 6Likes
post #1 of 11 (permalink) Old 05-30-2018, 11:35 AM Thread Starter
kezzy39's Avatar
Default Engine Loud Ticking Noise
I got back from work yesterday, shut off the bike. Hot day +32C. Opened garage and when I restarted the bike to move it into the garage a loud ticking noise(lifter,cam i think) started. Quickly parked and shut off the bike. Let the bike sit for 10 minutes to cool a bit. Restarted the bike and no noise. 2014 CC. 33,000kms on it now. Oil level good. Always use Vic stuff every 5,000kms. Stage 1 only on the bike. No other mods. Could this just be a trick sticky lifter acting up? I don't ride hard. 75% highway miles. First time this has happened. Has anyone experienced this? Is it something to be worried about?
2014 Cross Country. Stage 1 Exhaust Upgrade. LED Headlight. Keyless Ignition. Victory Chrome Bling.Winnipeg Manitoba Canada.
kezzy39 is offline
post #2 of 11 (permalink) Old 05-30-2018, 01:34 PM
No worries unless it becomes a regular thing.
One of the cam followers or cam chain tensioners failed to pump up completely. Wifes bike did a lot of this when new.
Hers turned out to be a defective cam chain tensioner in the front cylinder. It had a problem nearly from day one.
One event wouldn't concern me in the least. All it takes is the least amount of gum or a particle in the oil etc that lodges in the valving of either the cam chain tensioners or the self adjusting cam followers. Might have just been the temp rise from letting it heat soak in the driveway while you were negotiating with the garage door that caused the problem.
If it starts to happen frequently check back.
visionjohnny and kezzy39 like this.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #3 of 11 (permalink) Old 05-30-2018, 01:36 PM Thread Starter
kezzy39's Avatar
Thanks for the input. Much appreciated
kezzy39 is offline
post #4 of 11 (permalink) Old 05-30-2018, 01:43 PM
Just asking is all.
Do you have bike vertical when checking oil and do you screw in dipstick and then out to get reading.
So many guys buy their bike used and never get owners book to find out how to check the oil.
My bike ticks when I start it on the kick stand but only for about 30 seconds. Good Luck
post #5 of 11 (permalink) Old 05-30-2018, 01:45 PM Thread Starter
kezzy39's Avatar
I use the lift to get it vertical then check oil.
kezzy39 is offline
post #6 of 11 (permalink) Old 05-30-2018, 01:46 PM Thread Starter
kezzy39's Avatar
And screw all the way in to get accurate reading.
kezzy39 is offline
post #7 of 11 (permalink) Old 05-30-2018, 04:03 PM
I was getting lifter noise when using Vic oil and switched to Rotella T6 and that quieted them. Stayed with Rotella since then.
post #8 of 11 (permalink) Old 05-30-2018, 04:12 PM Thread Starter
kezzy39's Avatar
Going to try that once my extended warranty expires to quiet the slight lifter noise that has always been there.
kezzy39 is offline
post #9 of 11 (permalink) Old 05-30-2018, 09:37 PM
As far as I know, using another oil that's motorcycle rated, will not affect your warranty. Look on the back label on a jug of T6 and you will see it is JASO MA/MA2 rated. It don't get no better than that. And besides, being intended for Diesel engines, it has a much heavier engine protection additive package. Good stuff.
kezzy39 likes this.
post #10 of 11 (permalink) Old 06-01-2018, 01:22 AM
What T6 are you using? 15-40?
2000 Yamaha VStar Classic (Current)
2013 Victory High Ball (R.I.P)
Alberta, Canada
Rootzee is offline
