HELP please! Oil leak - Victory Forums - Victory Motorcycle Forum
 7Likes
post #1 of 23 (permalink) Old 06-07-2018, 07:50 PM Thread Starter
ChiTownVegas's Avatar
Default HELP please! Oil leak
I'm on the side of the road and well... This
~20k on the odo...
Cooler seems clean so I'm scared it might be more serious. Any ideas?
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #2 of 23 (permalink) Old 06-07-2018, 08:12 PM
DirtyDan's Avatar
From the spot on the cement it looks like one of the oil lines. I would wipe everything down real good and then put down a clean piece of cardboard. The wait for the spot to appear and trace it back.
visionjohnny likes this.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #3 of 23 (permalink) Old 06-07-2018, 08:18 PM Thread Starter
Found it! Damn... Tow is gonna be more than the part.
O2 wore through the cooler. How the hell?
Had these pipes on for more than 12k
2012 Vegas 8 Ball
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
post #4 of 23 (permalink) Old 06-07-2018, 09:55 PM
Good reason to remove the O2 sensors like most of us have.
visionjohnny and Motorbikerx like this.
post #5 of 23 (permalink) Old 06-07-2018, 10:10 PM Thread Starter
It's been awhile since I've been on here as well... The bike just works.
That said, don't think that'll work for me. It's a 2012 with intake exhaust and cams. Has a power commander with auto tune.
Can't believe they want 275 bucks for that piece of metal.
2012 Vegas 8 Ball
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
post #6 of 23 (permalink) Old 06-07-2018, 10:32 PM
ammo_umb's Avatar
Do you have Facebook? If so look for Victory buy and sell or victory motorcycle owners. Both have a few dealers that have new or used parts. Chances are someone will have a part off a crash bike that will cost much less.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #7 of 23 (permalink) Old 06-07-2018, 11:56 PM
Default cooler
If you are in a bind by-pass the cooler. If you are not in the desert anyway. I would do it if I had to get home. Also you can run an aftermarket cooler or get one off of another vehicle if you do not want to pay the big bucks. I know some will say but you can not do that, I say bs. Just think in a few short years you will not being able to buy a stock oil cooler for these bikes, then you will have to come up with a different cooler to use. Oh yes and you might be able to have it repaired at a GOOD radiator shop.
RICZ and Motorbikerx like this.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #8 of 23 (permalink) Old 06-08-2018, 02:40 AM
Motorbikerx's Avatar
Yeah it should solder up, flush some degreaser through it to get rid of oil traces flush with water then methylated sprit to get rid of water,
Should then be clean enough to solder up
And get rid of the O2s
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 23 (permalink) Old 06-08-2018, 09:04 AM
DirtyDan's Avatar
https://www.ebay.com/sch/177981/i.ht...Desc=0&_sop=15
Chattanooga Mark and BP6666VR like this.
All sold
2012 XCT,
2003 FLHTCUI
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #10 of 23 (permalink) Old 06-08-2018, 02:13 PM
If you can't find one look for a radiator shop they should be able to fix it
