Power Commander Bypass - Victory Forums - Victory Motorcycle Forum
 15Likes
post #1 of 16 (permalink) Old 07-09-2018, 12:41 AM Thread Starter
Wickman's Avatar
Default Power Commander Bypass
I got a trip planned next week in an area of the country that is extremely scenic but at the same time not very populated as well as no cell service, I will actually have to carry extra gas for this trip. My bike on the other hand is running like a champ but at the same time I prefer to play on the side of caution. To the question , with my bike running the power commander 5 what are my options of getting the bike to run off the stock ecu if I have any problems with the power commander? Do I need to completely remove it from the harness plus power and ground and injector connectors ?
Wickman is offline
post #2 of 16 (permalink) Old 07-09-2018, 06:22 AM
Edit: I'd pull the ground wire and see what happens. Do as you will😋
Wickman likes this.
2016 Victory Magnum
Lloydz air filter
Ragin Cajun slipons
PowerVision CX
Tenax is offline
post #3 of 16 (permalink) Old 07-09-2018, 10:34 AM Thread Starter
Wickman's Avatar
Is it that easy , just remove ground?
1/4 turn throttle
Madstad windshield
Loyd's A/C
Drew Miller Mufflers
Maximus tuned
Wickman is offline
post #4 of 16 (permalink) Old 07-09-2018, 12:52 PM
Instead of guessing get a hold of PC
Wickman likes this.
post #5 of 16 (permalink) Old 07-09-2018, 03:30 PM
My PCV has been installed for the past 48K miles with zero issues. Relax friend, you'll be fine unless something was done wrong with the installation that has you nervous. For that matter, your fuel pump could go out as could your CPU or your headlight, a dry wall screw could puncture a tire sidewall or your drive belt could break. Many things 'could' go wrong. You can't chase or plan for them all or you'd very likely never leave the house.
Enjoy the journey, take a credit card with room on it for emergency's and sign up for AAA RV Plus if you haven't already done so. With AAA RV Plus they'll tow your bike up to 200 miles. See, no need to bring excessive tools or parts. Just ride, have fun, be cautions and repeat as often as possible.
tfkp and Wickman like this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is online now
post #6 of 16 (permalink) Old 07-10-2018, 12:04 AM
adamnorthup's Avatar
I don't know if pulling the power to the PCV makes it default to an unmodified state - they could tell you & it may say in the manual? If you just take the PCV out of the loop by connecting the original injector M/F connectors back together, that takes it out of the loop & everything runs as original.
That being said, they seem pretty reliable!
Have a good trip!
XC, KP, & Custom MuscleVic in Boise
Chattanooga Mark and Wickman like this.
adamnorthup is offline
post #7 of 16 (permalink) Old 07-10-2018, 07:04 PM
Depending on how they are wired you might need to disconnect all of it for bike to run. No experience with them just speculating.
Wickman likes this.
IndyVictory is online now
post #8 of 16 (permalink) Old 07-10-2018, 09:37 PM
depot picker's Avatar
I'm pretty sure you just remove power from the PC.
adamnorthup and Wickman like this.
depot picker is offline
post #9 of 16 (permalink) Old 07-11-2018, 07:35 PM
This thread made me curious about how to handle a PC-V failure on the road.
I messaged Dyno-jet to find out. My question and their answer are below.
From me:
Have 2 bikes with PC-V'sNeither bike is so heavily modified that it could not be run without damage without the power commander. They are just there to improve the way it runs.If I am traveling and the PC-V were to fail on my bike must I remove it completely or will just removing the power to it or the ground to it take it out of the loop and allow the bike to run off the original mapping in the ECM so I can complete my trip?What is the easiest way to get it out of the engine management loop and get on with my trip?
Their reply:
Hello Joe. If the Power Commander V physically failed, you would have to completely remove it from the connections on the bike. The PCV intercepts the signals going to the injectors and takes over control of firing the injectors, so if it fails, the injectors will not fire. You would have to remove and plug everything back in as it was stock.
Keith Lockliear
Technical Support Manager
Dynojet Research, Inc.
Free: (800)992-3525
It only took them a few hours to answer my question which was pleasantly surprising.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #10 of 16 (permalink) Old 07-12-2018, 11:24 AM Thread Starter
Wickman's Avatar
From me:
Their reply:
Keith Lockliear
Free: (800)992-3525
I did my trip and before I left I sent the same sort of email to PC and when I stopped in a town where I could get a signal on phone checked my emails and I got the same response back as you did.
So as I said did the 1100 km day trip with no issues.
1/4 turn throttle
Madstad windshield
Loyd's A/C
Maximus tuned
Wickman is offline
