Part number for thin sealing washers - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 09-10-2018, 03:04 PM Thread Starter
Default Part number for thin sealing washers
Does anyone have the correct part number for the thin sealing washers used when installing the shifter ratchet to eliminate some of the side play in the installed ratchet?
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #2 of 17 (permalink) Old 09-10-2018, 04:01 PM
Isn't it just simply the thinner drain plug washer?
RICZ is online now
post #3 of 17 (permalink) Old 09-10-2018, 05:27 PM
Honda East Toledo's Avatar
Yes??? the copper one you mean off like the 2008 and up?
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #4 of 17 (permalink) Old 09-10-2018, 05:31 PM
How about that?
(877)-437-1631
Like us on Facebook
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
post #5 of 17 (permalink) Old 09-10-2018, 05:41 PM Thread Starter
I'm not sure if the 2008 up ones are the thin or the thicker ones.
In some of the threads I read here people have tried to use drain plug washers to shim the ratchet asm only to find that the ones they were sold were too thick. That's the problem. Not sure if the thinner ones are some early version or a later version of the same part number or are a completely different part number.
Any thoughts?
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #6 of 17 (permalink) Old 09-10-2018, 11:53 PM Thread Starter
Default Bump
Anyone know if the drain plug washers that Polaris is using to fill orders with now are the thin ones that will work to shim the shifter ratchet or the thick ones that are too thick to be use as shims for that ratchet assembly?
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #7 of 17 (permalink) Old 09-11-2018, 07:18 PM
I'm confused what you are shimming but have you tried a hardware store?
A real hardware store not Lowe's and Home Depot.
post #8 of 17 (permalink) Old 09-11-2018, 07:51 PM
doobliss's Avatar
In a nutshell, a drain plug crush washer can be used to eliminate side to side play on the shift shaft. My memory is failing me this evening, so I cannot say specifically where the washer goes.
'15 Gloss Titanium XC.
WOLO Low Tone Disc Horn
Tri-Oval Slip Ons
Black LED Headlight
Kingpin Metal Fork Guards
Ricz Lay Down Plate
Lloydz Timing Wheel & Throttle Ring
Shinhopples Grip Covers
12" Long Ride Shield
Bad Ace Billet Fork Mounted Air Deflector
Ness Signals; Amber front, Red rear
http://www.pure-gas.org/
"I leave the BUG CARNAGE on my screen , it adds character!"-LILMAGS500
doobliss is offline
post #9 of 17 (permalink) Old 09-11-2018, 07:53 PM
The annoying sloppy shift lever? I'd be interested in the fix for that but I have gotten used to it.
post #10 of 17 (permalink) Old 09-11-2018, 08:28 PM
doobliss's Avatar
Buywitchdoctors.com has a set of brass bushings that replaced the plastic bushings on the shift lever. The crush washer is for side to side movement of the shaft itself.
Tri-Oval Slip Ons
Black LED Headlight
Ricz Lay Down Plate
doobliss is offline
