106 clutch replacement parts, tools list? - Victory Forums - Victory Motorcycle Forum
 6Likes
  • 1 Post By 53canuck
  • 1 Post By depot picker
  • 2 Post By DaveT
  • 2 Post By TNXR
post #1 of 8 (permalink) Old 09-14-2018, 02:33 AM Thread Starter
JEGood's Avatar
Default 106 clutch replacement parts, tools list?
Hello everyone, I am going to replace the clutch plates in my 2013 vegas 8 Ball. I can only find one video on the tube, and it starts with the primary cover already off. I know I need plates obviously, I know about the spring compression tool and the primary gasket, and snap ring pliers. What else do I need in order to get it taken apart and put back together correctly? Thanks.
JEGood is offline
post #2 of 8 (permalink) Old 09-14-2018, 08:40 AM
A 6 pack...
Actually, there are lots of videos on clutch replacement. You don't need to stay specific to Vic's to learn a thing or two.
Watch a few and you'll do fine.
DaveT likes this.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #3 of 8 (permalink) Old 09-14-2018, 01:49 PM
This will be the same as yours. Listen up
post #4 of 8 (permalink) Old 09-14-2018, 03:46 PM
Honda East Toledo's Avatar
Keep digging, there are are at least 10 videos I found for clutch replacement.
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #5 of 8 (permalink) Old 09-14-2018, 04:35 PM
I think if I ever remove that cover it will get swapped to a black one.
Hope to not need clutch work for long time though.
IndyVictory is online now
post #6 of 8 (permalink) Old 09-14-2018, 06:16 PM
depot picker's Avatar
You will need a service manual. Read the procedure a few times before you start. Have the manual open as you do the job.
DaveT likes this.
depot picker is online now
post #7 of 8 (permalink) Old 09-14-2018, 09:26 PM
DaveT's Avatar
Count how many bolts hold the primary cover in-place. Buy that many 2 1/2" -3" bolts (think they're 6mm but take one out and measure it a hardware store). Then cut the tops of the replacement bolts.
When reassemblin' the cover to the engine, screw these long headless bolts into the engine casing then, put the gasket on the engine (using the bolts as a guide). Ease the primary cover back on the engine. Then, substitute the original bolts one at a time for the "guide" bolts. Remember to install and torque the bolts cross-ways.
This process, although sounds tedious, will help with keeping the gasket square and from bunchin' up (or slippin'). Also, it makes puttin' the primary cover back on a lot easier.
There are more suggestions but they're mostly in the videos.
G'Luck!
MrXC2014 and olddad64 like this.
DaveT is offline
post #8 of 8 (permalink) Old 09-15-2018, 06:31 AM
TNXR's Avatar
If your any thing like me then it will be a pain in the *ss and you will screw something up and/or get it back together and see an important part still laying on your garage floor! After it is over though you will have knowledge and a new skill that you didn't have before and your next clutch job will be much easier!
Speedblue and DaveT like this.
2011 Cross Roads Sunset Red
TNXR is offline
