Vegas running like shit! - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By Motorbikerx
post #1 of 4 (permalink) Old 09-19-2018, 08:33 AM Thread Starter
Motorbikerx's Avatar
Default Vegas running like shit!
Started her up tonight to go get milk.
Hesitated starting, then backfired up the intake as it did.
Started up but was backfiring out the torquetubes and popping and farting out the exhaust.
I rode to get milk and filled with premium fuel while there , restarted and running like a bag of shit!
Sounded more like a souped up harley with a massive cam at idle than a finely tuned Vic....
Rode home thinking new plugs in the morning, cant be battery terminals did them last week.
Pop off the air pods from the torquetubes as theyre a bit filthy which is good really but just as well as I took em off I spot what I reckon is the problem, a vacuum pipe has popped off where the rubber elbow is going into the front throttle body!
Took a pic for you them reconnected
Then running sweet again, well as sweet as a bored and cammed Vic can run..
Took the opportunity to spray some intake cleaner foam down the Tubes as I held the revs on 2000.
Then some KN Filter cleaner now Im gonna hose clean em with water and let em dry out overnight.
Going horseriding in the morning...that right on the 4 legged kind, one horse not 115
Anyway this is what the Vic sounded like in case you have a similar problem youll know what it is...
https://youtu.be/72HqAw27kX4
Cant put pic of hose up cos sites still dodgy since they 'fixed it' for us!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #2 of 4 (permalink) Old 09-19-2018, 08:45 AM
BP6666VR's Avatar
That did sound rough ... Glad you found the loose vacuum hose
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 4 (permalink) Old 09-21-2018, 06:46 PM
Oh, man, I've seen shit run and it ain't pretty!!!
2010 Jackpot, 19k miles, Torque Tube, Bassani and more.
BadBoyZ is offline
post #4 of 4 (permalink) Old 09-21-2018, 08:10 PM Thread Starter
Yeah, I take MSM and Magnesium in the morning and thought if one spoon of magnesiums good then two spoons be better.......sheeeeeit!!!
RICZ likes this.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
