a lil more top end speed. - Victory Forums - Victory Motorcycle Forum
 28Likes
post #1 of 27 (permalink) Old 09-27-2018, 11:27 PM Thread Starter
psychodiablo's Avatar
Send a message via AIM to psychodiablo
Default a lil more top end speed.
without going to wild with cams,super tuner and getting into the engine. what pully combos would net a better top end without sacrficing to much giddy up and mileage.
Leesville Louisiana. 2012 cross country, speedo upgrade,forged engine guard,touring sheild, tri oval pipes, Lloyds gen 3 fuel controler, Lloyds highflow airfilter. Lloyds timeing wheel, msd coils,Lloyds 8.2 mm red wires,tank lift/spacers,tank wings,side cover scoops,audio input cord,drivers back rest, 2in pull back bars,polk 5.25 speakers,XC Mag baffles,rockford fosgate pbr400x4 amp,lower wind deflectors,sylvainia ZXE Gold h-11 headlights. rivco hiden hitch. IDMW,FYIYDLMOMB.
psychodiablo is offline
post #2 of 27 (permalink) Old 09-28-2018, 12:38 AM
The Conquest Customs Under Drive pulley will increase your get up and go. Now, adding Lloyds cams, a PCV, air cleaner, timing wheel, slip on mufflers and a dyno tune will make the stock bike seem like it's a whole different bike with much more get up and go. The UD pulley will come at a reduction in top end, all other parameters being equal. I 'think' about a 7% reduction in top end. Nearly everyone who installed the UD pulley seems to like it, a lot. It greatly depends on your riding style and where you ride most. The performance items mentioned above, except the UD pulley are all considered the low hanging fruit (Stage One) for the 106 motor. It really responds well with these simple mods. Stage Two could be a Big Bore kit and Stage Three would be a super charger. But a big bore kit alone nearly exceeds the cash value of a 2012 CC. The blower too and you'd be way upside down from a cash value perspective.
PS - I think the red MSD coils look about as cool as can be mounted on the 106 motor. Good for you for having them already.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #3 of 27 (permalink) Old 09-28-2018, 01:10 AM Thread Starter
i liked the look of the coils and wires a bit better than the stock look to. i do have the gen 3 loyds fuel controller,timing wheel at +4,and loyds air filter. i think i could use a steering stableizer to help control the higher speed movement . do you think i could get a lil bit faster by putting the shorter stock sheild on insted of the touring sheild and remove the fork air deflectors.
post #4 of 27 (permalink) Old 09-28-2018, 05:45 AM
half_crazy's Avatar
You realize that your bike has a speed limiter (electronic) and will not exceed 122 mph or so?
You will go faster in 5th gear than 6th.
Weight and wind resistance meet horsepower and that's all ya get... if you want to go faster it takes horsepower.
@Chattanooga Mark is right, the underdrive pulley will probably shorten the gearing enough to make top speed higher. Since the bike is geared to go 140 in 5th... but doesn't have the HP to pull the bike through the wind to 140 mph in 5th... shorter gearing will allow it to go a little faster before it hits the wind/weight wall.
Face it, the bike is heavy and has things to block the wind out front. Aerodynamics is not 100% how you cut through the air... a lot of it is about how smoothly you replace the air behind you (less drag). Look at a streamliner...
When I ride behind guys with big 'cop shields' or full fairings I feel their turbulent wake... like following a minivan...
2006 Victory Kingpin
half_crazy is offline
post #5 of 27 (permalink) Old 09-28-2018, 09:11 AM Thread Starter
for some reason i didnt realise the the top limit of around 122 or so. hell that is fast enough for me any ways. cant afford to put the stuff in it to go any faster.
Chattanooga Mark likes this.
post #6 of 27 (permalink) Old 09-28-2018, 09:38 AM
I have a CCT with the mods as shown below. My CCT windshield is 3" shorter than oem and instead of the CCT lowers, I have forged bars with JTD inserts. My bike 'can' go over 110 mph but it really doesn't 'want' to. Like HC said, it's faster in 5th than 6th. Realistically at much over 100 mph, the CC/CCT simply has to move too much air. Also, at those speeds it's likely not a speeding ticket alone. You could very well be getting a free ride in a squad car. Adding cams to your current setup will transform your CC. Not with big increases in top end Hp and/or speed. But in the meat of the rpm range you use 80% to 90% of the time. Look at some of the posted dyno graphs. The 'pie shape' improvement is simply night and day. If you have stock mufflers, maybe add some freer flowing ones at the exhaust end to keep pace with the intake. There are many options available without spending a lot of money. Gonzo Garage, Raging Cajun and Drew Miller to name a few. All three of these muffler modifiers have options in sound level as well.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
post #7 of 27 (permalink) Old 09-28-2018, 10:42 AM
Usually 30 over is a free ride in any state. I have read that bike is unstable in triple digits I've not gone that far but did push past 90 keeping up with traffic in Michigan...
If you are doing high speed regularly I think that stabilizer is a good plan. Fork mounted fairing can seriously mess up your steering as wind conditions change.
Rev limiter stock ECU is much lower in 6th but I fixed that with my flash tuner.
Have fun with your projects.
post #8 of 27 (permalink) Old 09-28-2018, 12:32 PM Thread Starter
i have triovals for exhaust.
post #9 of 27 (permalink) Old 09-28-2018, 12:35 PM Thread Starter
much over 100 now it starts to shake a lil bit. i dont do triple digits to often
post #10 of 27 (permalink) Old 09-28-2018, 09:49 PM
So many things become so critical at elevated speeds. Things like tire pressure/balance/wear, wheel/steering/swingarm bearing condition, windshield height/shape, lowers, handlebar and grip position, cargo weight distribution etc etc etc.
One of the biggest influences on elevated speed stability is simply the rider position and hand grip pressure. There's not an inherent design flaw or reason for a CC or a CCT to wobble at 100+ mph. Some people say there's does while others say there's do not. The factors mentioned above and the rider will greatly determine high speed stability. Relax, lighten your grip, correct your body position and if your bike is properly maintained, it should not have a high speed wobble. Obviously cross winds and road conditions also play a big factor.
Though neither a CC nor a CCT were really designed to run much at 100+ mph.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
