Clutch Cable Question - Victory Forums - Victory Motorcycle Forum
 17Likes
post #1 of 15 (permalink) Old 12-16-2018, 08:26 PM Thread Starter
Default Clutch Cable Question
I did a search but no luck.
I have a new to me 2012 CCT. I just cleaned and re-greased the clutch cable and noticed the barrels on my current cable have a black plastic sleeves. I'm wondering if the cable has been replaced. Does this sound like an OEM Clutch?
Thanks,
LB
LarryBud is offline
post #2 of 15 (permalink) Old 12-16-2018, 09:18 PM
Yes, that's the original equipment cable. If the previous owner kept the ends - just the ends and not the cable - cleaned and lubed, and you do the same, you should be OK. If you see any fraying of the cable next to the barrel, it's getting ready to break. If you want a superior cable with heftier ends, install a Barnett, you'll also get an easier pull too.
post #3 of 15 (permalink) Old 12-17-2018, 04:34 AM Thread Starter
Thanks RICZ. I suspected as much. I didn't see any fraying but it looked like it's been a while since last serviced.
How challenging of a DIY job is installing the Barnett? An easier pull is an attractive advantage. Plus, I like the idea of the fresh start.
LB
LarryBud is offline
post #4 of 15 (permalink) Old 12-17-2018, 05:15 AM
BP6666VR's Avatar
LB
Most have a Barnett cable and it is smoother indeed, it is a tedious job but easy to do, i removed the tank coz that is the easiest way ...
Andre using TaPaTaLk
RICZ likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 15 (permalink) Old 12-17-2018, 01:33 PM
Yeah, it's best to remove the tank and have a buddy to help. It also helps to have the tank empty or near empty. Have lots of zip ties on hand. Like Andre said, it's not a hard job. It might take a couple hours.
visionjohnny and BP6666VR like this.
post #6 of 15 (permalink) Old 12-18-2018, 10:24 AM
BenD's Avatar
Hereís how I changed my cable: disconnect from ends, and cut zip ties. Tie kite string to handlebar end and pull slowly through fairing, then tie string to new cable and pull back through fairing. Re-connect ends, add zip ties, and adjust tension. 45-60 minutes and done.
2012 XC Tour, Sunset Red/Silver PC-5 Thrush mod pipes Lloydz air filter and timing wheel.
California Sidecar Trike Conversion
Phoenix, AZ
BenD is offline
post #7 of 15 (permalink) Old 12-18-2018, 04:02 PM
Richie271's Avatar
That's the way I have done mine twice.
Richie271
Long Island, NY
2010 Cross Roads. Midnight Cherry.
Richie271 is offline
post #8 of 15 (permalink) Old 12-18-2018, 09:47 PM
depot picker's Avatar
Iíll have to try that next time. I always pulled the cowling and loosened the inner cowl
depot picker is offline
post #9 of 15 (permalink) Old 12-20-2018, 06:11 AM
pbounds's Avatar
Send a message via Yahoo to pbounds
My first clutch cable replacement I did was with a factory cable on my 2012 HighBall, and it had those small plastic sleeves. Second time around I went with the Barnett too from Witchdoctor's. One thing that led to that decision was the cable got better reviews, and you can also get the cable with the little bit of extra cable. I always thought when I did my first cable replacement it was just on the verge of being a little too tight tolerant. On the Barnett, I didn't mind that little extra 'bow' up by the ape hangers...
pbounds is offline
post #10 of 15 (permalink) Old 12-20-2018, 06:32 AM
I looked at the cable routing I don't see why removing tank would be needed on CCT. Hopefully the cable lasts a while. I do have Barnett cable if the stock fails. It does look like the ends are better built. I was told once buying a backup cable will prevent the first from failing. Worked so far on the other bike.
BenD, cooper, Motorbikerx and 2 others like this.
