Replacement Fuel Lines of Victory Fuel Rail - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 17 (permalink) Old 12-27-2018, 06:24 AM Thread Starter
Quinton Johnson's Avatar
Default Replacement Fuel Lines of Victory Fuel Rail
Hey All,
So Recently, one of the lines that goes from my injector to the fuel rail tore. I cannot find the individual part on any parts diagram, only the entire fuel rail sold complete.
My question is, does anyone know of a good alternative line to use other than buying an entire new fuel rail? Would just a normal nylon / plastic line work that I can get from any old auto store?
Thanks!
2013 Victory Hammer 8ball
Quinton Johnson is offline
post #2 of 17 (permalink) Old 12-27-2018, 03:21 PM
Never had that problem, so I'm not familiar with that line. Is it a hose? Material? Rubber-like? Got clamps at either end? If so, my guess it is made to handle pressures and should be available at either an auto supply or air/oil systems supply.
post #3 of 17 (permalink) Old 12-27-2018, 07:42 PM
Pics would help those of us with no clue.
Can you use automotive parts on a motorcycle? If it's already broke I would try it.
If you do it document it with pics and a write up for the rest of us.
RICZ likes this.
post #4 of 17 (permalink) Old 12-28-2018, 01:41 AM
BP6666VR's Avatar
I agree with the answers above, if your up for it just replace it with a high pressure fuel hose, i removed the fuel rail once and it was a "[email protected]'/# to remove but the connection point did not look any different or special to me ...
Did you try DonWood website to buy the part separate ?
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 17 (permalink) Old 12-28-2018, 05:35 AM Thread Starter
Hey All,
Attached is not my picture, but a rough idea of the fuel line I will be replacing. I am under the impression that any old high pressure injector hose from an auto parts store will do the trick.
It is the hose that T's off from the fuel line from the tank into the rear cylinder injector. No clamps on the hose, just a super tight fit on the connection. I did remove the old one which was a true PITA. It doesn't look any different from the normal fuel line mounting slip on connection. Just was looking to see if anyone had any major input.
I have the heads off to get chrome plated again as the factory plating has chipped apart. Once the bike is back together I will update with what I did for the fuel line. Looks like a stop at my local auto source is in order.
post #6 of 17 (permalink) Old 12-28-2018, 06:20 AM
half_crazy's Avatar
Found it.... #6 Part # 2520881
https://www.cheapcycleparts.com/oemp...sm-all-options
2006 Victory Kingpin
half_crazy is offline
post #7 of 17 (permalink) Old 12-28-2018, 06:22 AM Thread Starter
Originally Posted by half_crazy View Post
Part #6 is the entire fuel rail assembly, not just the line. That whole assembly is nearly $300. I can't find a part number for just the hose connecting it all.
post #8 of 17 (permalink) Old 12-28-2018, 07:15 AM
half_crazy's Avatar
And you won't...
post #9 of 17 (permalink) Old 12-28-2018, 08:31 AM
I do not see why a good quality auto high pressure fuel hose would not work? Likely the cheapest route would be take it off and carry to an auto store to match up the hose and size etc up. If you plan to replace the whole fuel rail which might be easier it will be costly, but you can likely find a used one on ebay for under $100.00.
cal_105215 is offline
post #10 of 17 (permalink) Old 12-28-2018, 08:34 AM
There's quite a few used ones available on eBay when I searched for "victory 2520881":
https://www.ebay.com/sch/i.html?_fro...20881&_sacat=0
half_crazy and BP6666VR like this.
