Dynojet Auto Tuner - AT 200 - Victory Forums - Victory Motorcycle Forum
 4Likes
  • 3 Post By vindex1963
  • 1 Post By SportyDoug
post #1 of 6 (permalink) Old 03-04-2019, 06:54 PM Thread Starter
Default Dynojet Auto Tuner - AT 200
Picked one up on a whim, although I don't have a tuner on my bike. If i put a PCV on my Jackpot, will it actually save me from Dyno tuning, as they claim?
2010 Jackpot, 19k miles, Torque Tube, Bassani and more.
BadBoyZ is offline
post #2 of 6 (permalink) Old 03-04-2019, 07:42 PM
depot picker's Avatar
AT200 is not for a Vic. You need an AT 300 and a PCv.
depot picker is offline
post #3 of 6 (permalink) Old 03-05-2019, 07:37 AM
The AT200 and AT300 are basically the same; the AT200 has a single O2 sensor and the AT300 has dual O2 sensors. They both require a connection to a PCV.
Auto Tune Kit, Autotune, Power Commander AutoTune
"Part #: AT-200
This version is a "universal fit", single O2 sensor kit. It can be used on any vehicle that has a PCV installed on it. It comes with a single O2 sensor, "cut to length" sensor cable, control module, O2 sensor, one weld boss kit, a CAN connection cable, and CAN termination plug. It requires a ground and +12 volt connection to be made using the supplied wiring hardware. .
Part #: AT-300
This Auto-tune Universal kit is designed for twin cylinder motorcycles/ATVs that use the Power Commander V allowing control of two cylinders separately and simultaneously. The kit includes two O2 sensors, a control module with 2 sensor inputs, a CAN connection cable, CAN termination plug, two custom length sensor cables, and two weld boss kits. It also requires a ground and +12 volt connection to be made using the supplied wiring hardware."
I used an AT300 for a bit and seemed to do a good job, but then I got it dynoed and I sold the AutoTune.
broggyr is online now
post #4 of 6 (permalink) Old 03-07-2019, 01:41 PM
SportyDoug's Avatar
Have never used the PCV, but have put Dobeck products on a number of my bikes, enjoying good results w/o a dyno tune. Does the bike run as well as it would with a dyno tune? No, but I was never all that great a racer to begin with.
EFI - Electronic Fuel Injection Controllers - ATVs, UTVs, Motorcycles, Snowmobiles, Scooters, Sport Bikes, Watercraft
Good luck with your project.
SportyDoug is offline
post #5 of 6 (permalink) Old 03-08-2019, 06:01 AM
vindex1963's Avatar
What does racing have to do with a properly tuned motorcycle?
broggyr, Motorbikerx and ScabbyDoo like this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #6 of 6 (permalink) Old 03-14-2019, 08:38 PM
SportyDoug's Avatar
Oh, my bikes are kept properly tuned, just not perfectly tuned.
Chuckz71 likes this.
Similar Threads
Thread Thread Starter Forum Replies Last Post
DynoJet AT-300 Auto Tune broggyr Motorcycle Parts For Sale / Wanted 1 09-18-2018 05:53 PM
WTB- Dynojet LCD 200 raptout Motorcycle Parts For Sale / Wanted 0 07-12-2016 05:09 PM
Dynojet Auto tune antifreeze green Victory Cross Country and Cross Roads 6 02-01-2016 05:33 PM
Dynojet Autotune AT300 / $200 OBO holleyj3 Motorcycle Parts For Sale / Wanted 6 03-29-2013 12:35 PM
