Victory Hammer Lloydz Cam Replacement Question - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 1 Post By NOEMTZ
  • 2 Post By Motorbikerx
post #1 of 6 (permalink) Old 03-30-2019, 02:59 PM Thread Starter
Quinton Johnson's Avatar
Default Victory Hammer Lloydz Cam Replacement Question
Hey all,
I am replacing the cams in my victory at the moment and have read and watched about every video and forum there is on the topic.
Rear cam is in without issues.
front cam is almost there, but that is where I ran into an issue. I cannot get the cam chain back on the actual cam. the rear went on without a problem. The engine is locked in TDC and the chain is zip tied to the wheel so it cannot move. however I really cant get the wheel back on the cam itself. any suggestions?
Yes I have the chain tensioner out, but that didn't really help me
Thanks in advance
2013 Victory Hammer 8ball
Quinton Johnson is offline
post #2 of 6 (permalink) Old 03-30-2019, 04:48 PM Thread Starter
UPDATE:
I got it on finally, but for some reason the marks on the cam do not line up with the wheel. I have attached a picture. The motor is pinned at TDC and has not moved, and my chain is zip tied to the wheel so that also did not move. any suggestions?
post #3 of 6 (permalink) Old 03-30-2019, 07:11 PM
NOEMTZ's Avatar
Post pic of crankshaft. If crank actually at TDC, then rotation of cam and gear is needed, loosen carrier first. If crank 180 degrees out, rotation of crank needed to get to TDC with cam out. Then reinstall cam and gear at TDC.
www.noemtz.com
NOEMTZ is offline
post #4 of 6 (permalink) Old 03-30-2019, 07:13 PM
NOEMTZ's Avatar
Originally Posted by Quinton Johnson View Post
UPDATE:
looks like cam is 180 out, but want to see crank shaft position.
Chuckz71 likes this.
www.noemtz.com
NOEMTZ is offline
post #5 of 6 (permalink) Old 03-31-2019, 06:55 AM
Motorbikerx's Avatar
Hey all,
Thanks in advance
I just did something similar and buttoned it all up and had me a one cylinder Victory just running on the rear, rang Kevinx and sent him pics of the front cam markings turned out I had got the front cam in upside down, So Kevin suggested I unbolt the cam sprocket and carefully turn the engine through by hand till the front lined up properly and then bolt the cam sprocket back to the cam.'
Worked a treat!
I thought Ihave to unbolt the cam carrier again after everything was retorqued but doing it Kevs way made sense.
all the youtube vids I found were crap made by people waffling on and jumping past crucial steps, Vindex sent me the PDF of the S&S install instructions clear and precise...have a look back a few pages on my Back in Black thread and see if youve done what I did, if so theres an easy way out.
Chattanooga Mark and Chuckz71 like this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 6 (permalink) Old 04-06-2019, 06:25 AM Thread Starter
Thanks all for the suggestions. I ended up pulling the cam out, and cam carrier back out and reseating the whole thing and it ended up lining up. All good!
Similar Threads
Thread Thread Starter Forum Replies Last Post
To cam or not to cam wingnut Victory Cross Country and Cross Roads 18 08-25-2015 09:39 AM
My visit to the Vicshop - 07 Hammer w/Lloydz timing wheel & Lloydz ECU WildBlue Victory Tech and Performance Section 11 08-10-2014 07:52 AM
Someone needs to please do a Lloydz VM1 Cam Install Guide or Video... mobgma Victory General Discussion 36 05-13-2014 08:32 PM
VM1 cam VS OEM cam GrogAV Victory Cross Country and Cross Roads 42 02-05-2014 03:43 PM
proformance cam from lloydz poppamark Victory Tech and Performance Section 10 10-15-2011 11:08 AM
