PLEASE read BEFORE doing a cam change on your 106" motor - Victory Forums - Victory Motorcycle Forum
 11Likes
  • 3 Post By vindex1963
  • 2 Post By RICZ
  • 2 Post By BBob
  • 1 Post By Motorbikerx
post #1 of 5 (permalink) Old 04-06-2019, 09:23 AM Thread Starter
vindex1963's Avatar
Default PLEASE read BEFORE doing a cam change on your 106" motor
Step by step directions for changing cams on your 106" motor including all torque specs.
https://www.sscycle.com/docs/default...s.pdf?sfvrsn=2
BBob, visionjohnny and broggyr like this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #2 of 5 (permalink) Old 04-06-2019, 12:29 PM
If all else fails, read the instructions....eh Vindex?
post #3 of 5 (permalink) Old 04-06-2019, 02:18 PM
Good info. I tried uploading it to the Mediafire account with the rest of the downloads but for some reason it wouldn't do it so I'm adding the link to the list under general info/belt sizes/etc.
visionjohnny and vindex1963 like this.
BBob is online now
post #4 of 5 (permalink) Old 04-07-2019, 09:14 AM Thread Starter
vindex1963's Avatar
Does wonders, and now anyone can find them.
RICZ, BenD and broggyr like this.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #5 of 5 (permalink) Old 07-07-2019, 04:44 AM
Motorbikerx's Avatar
Thanks mate, wish Id found this before I did mine following the dudes on youtube.
Got it good in the end though😎
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using seafoam in the oil before doing a change? Tony.v Victory General Discussion 48 04-12-2019 10:05 AM
How about a "What did you ride before your Cross Country" thread! sickXC Victory Cross Country and Cross Roads 85 06-25-2016 11:21 PM
Change out "bullet" headlight to "round" Mattzlaff Victory 8-Ball 8 04-05-2016 06:20 PM
Hard-Krome Sideburners on a 106" motor? leighhannah Victory Tech and Performance Section 6 11-25-2011 08:34 PM
Please read our rules before posting administrator Rules and New Members Introductions 0 11-16-2007 03:04 PM
