Neutral Safety Switch Woes - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By mh1
post #1 of 3 (permalink) Old 04-29-2019, 03:35 PM Thread Starter
Default Neutral Safety Switch Woes
2005 Kingpin. Original neutral safety switch went out. Ordered a new OEM replacement. Everything back to normal for about two weeks and the new one went out. Anyone ever have an issue like this and what was your fix?
hades02 is offline
post #2 of 3 (permalink) Old 04-30-2019, 12:12 PM
mh1
mh1's Avatar
You may want to remove the switch and check it with a meter to verify that the switch actually failed. It might be the wire or connector that actually has the problem.
visionjohnny likes this.
2013 Cross Roads Classic
mh1 is offline
post #3 of 3 (permalink) Old 05-01-2019, 09:01 AM Thread Starter
I will have to test the switch however it starts right up when I ground the wire to a bolt but not when I attach it back to the switch. That's why I'm thinking it might be something damaging the switch.
hades02 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Neutral indicator switch Cjh Victory Cross Country and Cross Roads 6 05-22-2018 09:41 PM
DO NOT remove clutch safety switch rodhotter Victory General Discussion 7 08-14-2015 02:30 PM
Sidestand safety switch? soofle616 Victory Cross Country and Cross Roads 42 08-10-2015 10:12 AM
clutch safety switch removed rodhotter Victory General Discussion 3 08-07-2015 06:09 PM
Neutral Switch supafly94 Victory Tech and Performance Section 6 12-04-2010 06:16 AM
