Removing the headers on a vision - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 05-04-2019, 12:11 PM Thread Starter
Victory Joe 1961's Avatar
I bought a 2008 Vision about two months, and 5000 miles ago. It seems the guy I bought it from had damage to the rear pipe, and only replaced the heat shields. He had wrapped the pipe with exhaust tape, which muffled the noise, but of course did nothing to repair the pipe. I have a new set of pipes coming. What is the procedure for pulling the old pipes off and putting new ones on?
Victory Joe 1961 is offline
post #2 of 3 (permalink) Old 05-04-2019, 01:28 PM
Take mufflers off unbolt cross over pipe. Pull all heat shields ( hardware store will sell stainless hose clamps) you might have to cut heat shield straps. Now unhook front floor board and master cylinder. Let it hang down. Take header nuts off. Now you want to move rear pipe downwear and forworweard at the same time first then front header pipe. Put in NEW exhaust gaskets. You might need a pick to pray out old gaskets
post #3 of 3 (permalink) Old 05-04-2019, 03:43 PM Thread Starter
Thanks very much!!!
Similar Threads
Thread Thread Starter Forum Replies Last Post
Removing the valve covers WITHOUT removing the engine Tinstar5541 Victory Cross Country and Cross Roads 14 02-10-2015 01:45 AM
Vance & Hines Pro-pipe mated to stock victory headers? rumblebox Victory Tech and Performance Section 6 01-07-2014 08:12 PM
Torque Tube Headers - Lloydz turtle05lj Victory High-Ball 1 03-21-2013 02:25 PM
Factory pipes and headers jbb01 Motorcycle Parts For Sale / Wanted 0 04-19-2011 05:39 PM
removing baffle from exhaust? jcrider Victory Hammer Forum 4 04-23-2009 08:27 AM
