Cruise Control not working? - Victory Forums - Victory Motorcycle Forum
 5Likes
  • 2 Post By BenD
  • 3 Post By MrXC2014
post #1 of 9 (permalink) Old 06-17-2019, 09:05 AM Thread Starter
MrXC2014's Avatar
Default Cruise Control not working?
Looking for to suggestion on what to check for when I get home this evening, I notice that my CC wasn't working and the CC pwr indicator light is not lit, where can I find the pwr wire for that at I do not have a SVC manual??
2014 Victory CC, Two-Tone, VM1-HPT-DR, PC5, ATS+4, Llyodz HI-FLOW A/F, 1/4 Turn Throttle Ring, Tuned by Kyle Crandall of KMC PowerSports, Flashed ECM, 121hp 113tq
Suede Supersteel & Black, Madison, AL
MrXC2014 is offline
post #2 of 9 (permalink) Old 06-17-2019, 10:39 AM
BenD's Avatar
Open the fairing and then follow the wiring from the cc switch into the fairing. There is a gray, square shaped connector that may have come apart. I just found this on my bike, last Friday. Hope itís something as simple as that for you, because trying to trace the wires, even with a schematic is a PITA.
broggyr and SkInM4N like this.
2012 XC Tour, Sunset Red/Silver PC-5 Thrush mod pipes Lloydz air filter and timing wheel.
California Sidecar Trike Conversion
Phoenix, AZ
BenD is offline
post #3 of 9 (permalink) Old 06-17-2019, 11:44 AM
SkInM4N's Avatar
Couldn't have said it better myself
Skin
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #4 of 9 (permalink) Old 06-17-2019, 12:11 PM Thread Starter
MrXC2014's Avatar
Ok will do I was hoping I wouldn't have to take my fairing off.
MrXC2014 is offline
post #5 of 9 (permalink) Old 06-18-2019, 08:11 AM Thread Starter
MrXC2014's Avatar
Ok the culprit turned out to be the 10A CB called TS/Horn, not sure why the Cruise Control is a part of that but it's working.
BenD, SkInM4N and CanuckRob like this.
MrXC2014 is offline
post #6 of 9 (permalink) Old 06-18-2019, 08:20 AM
SkInM4N's Avatar
Yeah that is weird for sure. My horn just stopped working so I checked the TS/Horn fuse and it is fine. Now I guess I should check all of them in case it is tied to some other system for some reason.
Skin
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #7 of 9 (permalink) Old 06-18-2019, 08:28 AM Thread Starter
MrXC2014's Avatar
Skin, well seeing that the turn-signals & horn are running of the same CB and your TS are still working I would check pwr at the horn do you have one of those WOLO/STEBEL air horn?
MrXC2014 is offline
post #8 of 9 (permalink) Old 06-18-2019, 09:09 AM
SkInM4N's Avatar
It is the standard horn. I haven't changed it. I need to find the time to troubleshoot it but I am always super busy.
Skin
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #9 of 9 (permalink) Old 06-18-2019, 10:32 AM
BenD's Avatar
Iím sorry I didnít suggest that. Itís the first thing to eliminate as a cause, when the CC quits and you notice your horn and TS donít work.
Phoenix, AZ
BenD is offline
