Help with airing up of the rear shock??? - Victory Forums - Victory Motorcycle Forum
 6Likes
post #1 of 26 (permalink) Old 06-18-2019, 05:27 PM Thread Starter
MrXC2014's Avatar
Unhappy Help with airing up of the rear shock???
Ok I've had my XC for 5yrs now and I've never figured out how to properly air-up my shock, this is my second one and when every I connect the air pump which is the Fox Factory Shox pump to the air valve and attempt to pump the shock up I can set it to what every pressure say 40psi once I unscrew the pump off the stem it doesn't hold the pressure, is this a bad shock???
2014 Victory CC, Two-Tone, VM1-HPT-DR, PC5, ATS+4, Llyodz HI-FLOW A/F, 1/4 Turn Throttle Ring, Tuned by Kyle Crandall of KMC PowerSports, Flashed ECM, 121hp 113tq
Suede Supersteel & Black, Madison, AL
MrXC2014 is offline
post #2 of 26 (permalink) Old 06-18-2019, 05:44 PM
Mine was same pressure this spring as it was last fall when I put the cover on.
I say bad shock or you are letting air out when you unscrew it.
Can you pump it and watch the gauge to see if it drops?
Even walking away for a few minutes just leaving it connected.
IndyVictory is online now
post #3 of 26 (permalink) Old 06-18-2019, 05:49 PM Thread Starter
MrXC2014's Avatar
Yes so when I try and back off the air fitting it loses pressure and if I stop backing it off the it will stop leaking. Now as far as holding, it appears to hold the air but I didn't leave on very long to check it.
MrXC2014 is offline
post #4 of 26 (permalink) Old 06-18-2019, 06:10 PM
WeekendRider's Avatar
Either you’re missing the valve core or it is loose. You can buy a tool at the auto parts store for a few bucks.
https://www.motosport.com/hp-tools-s...000P-X001-Y001
yago20 likes this.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #5 of 26 (permalink) Old 06-18-2019, 06:18 PM
Oh, and the core has an o-ring on it that could be missing or damaged. Auto parts or bicycle shop will have the tool and should have a core that will fit if you need one. But most likely it is loose.
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #6 of 26 (permalink) Old 06-18-2019, 06:47 PM Thread Starter
MrXC2014's Avatar
WeekendRider with the pump still connected it's rock steady no leaks after 20mins it's only when I try and pump air into the shock it has some resistances and when I start unscrewing the pump then that's when I start losing pressure??
MrXC2014 is offline
post #7 of 26 (permalink) Old 06-18-2019, 06:48 PM
It looks like you're using the right pump for the job. They are designed to NOT lose air when you unscrew them from the valve though so something is not right. Either the pump valve is faulty or maybe as 'WeekendRider' said; the core isn't screwed in all the way or maybe the Schrader valve is bad and you just need a new one.
CanuckRob likes this.
post #8 of 26 (permalink) Old 06-18-2019, 06:56 PM Thread Starter
MrXC2014's Avatar
Do you think it's a standard valve or something specific Victory uses?
MrXC2014 is offline
post #9 of 26 (permalink) Old 06-18-2019, 07:05 PM
Pull it out and look at it. Maybe take it to a tire shop and see if they can match it up. I think it's probably just a standard Schrader valve since it doesn't handle much more than a 100 psi. Bicycle tire valves will do that.
post #10 of 26 (permalink) Old 06-18-2019, 07:25 PM Thread Starter
MrXC2014's Avatar
Alright let me go find this tool and see what I come up with Thanks everyone for your help I'll will post my finding when I get them.
MrXC2014 is offline
