Can't shift to First Gear - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 11 (permalink) Old 07-07-2019, 05:03 AM Thread Starter
Send a message via Skype™ to nealflora
Default Can't shift to First Gear
I have two Vics, 2012 Cross Roads and 2012 Vegas both seem to have the same issue. I have been off riding for about 8 weeks (surgery) and went out to take them both for a ride. First I drained all the gas and put fresh gas in them.
On the Vegas: When I pulled it out of the garage I had a tough time finding Neutral. Didn't think much about it but when I started out, could't get into first! 2nd and past I can get to fine.
On the XR, Got Neutral just fine but again won' go into first.
Don't know why not riding them would cause this but there must be some adjustment I need to make or process to free them up?
Thanks
Neal, Marco Island Florida-2012 Vegas, 2012 Cross Roads
nealflora is offline
post #2 of 11 (permalink) Old 07-07-2019, 08:04 AM
Motorbikerx's Avatar
take off in second, run it up through the gears then go back down, may be all it needs
Speedblue likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 11 (permalink) Old 07-07-2019, 08:06 AM Thread Starter
Thanks, I'll give it a try
post #4 of 11 (permalink) Old 07-07-2019, 08:54 AM
weakest link in the shift mechanism is the shift ratchet, the slightest burring of the edges of the claw will have it slipping past the starwheel.
Its good to fit the correct thickness oil drainplug washer to the shift shaft as you refit the primary, stops the sideways play that adds to the shift ratchets problems.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #5 of 11 (permalink) Old 07-07-2019, 08:56 AM
Start with the simple things first. Lube the external shift linkage. Sometimes they go dry and won't operate the internals right. Just some spray lube or white lithium grease will do.
If it that doesn't work then you might have a bent 'something' in the primary. If that isn't it then it's something in the transmission.
post #6 of 11 (permalink) Old 07-07-2019, 04:08 PM
Check the clutch cable adjustment. If you don't know what it is, it's in the owners manual.
post #7 of 11 (permalink) Old 07-07-2019, 05:17 PM
Didn't @id-man have something happen like this?
post #8 of 11 (permalink) Old 07-08-2019, 03:41 AM
Thanks
Strange they'd both do that after only 8 weeks sitting, and they were fine before that?
Like someone said, lube the linkages first up, and verify clutch adjustment is correct.
Whats the latest on this?
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 11 (permalink) Old 07-08-2019, 07:01 PM
RoteBaron's Avatar
Famous tag line from the US tabloids "Enquiring minds need to know." I have had two parked for sometime myself and will be getting them out next week and would like to know what to look for if it happens to mine (with a heartfelt thanks in advance to the OP). LMYR
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg
Victory High Flow Air Filter
2017 Highball - Suede Nuclear Sunset Orange
RoteBaron is offline
post #10 of 11 (permalink) Old 07-08-2019, 07:46 PM
Rote Baron....If you kept an automatic trickle charger on the battery and had the tank full to the top with fuel stabilizer added, you should be OK. Check tire air pressures. Before firing it up, remove the plugs and spin the starter a few seconds - this will get the oil circulating after it has settled.
BBob likes this.
