Fuel Leak???? - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By MrXC2014
post #1 of 7 (permalink) Old 07-09-2019, 09:25 PM Thread Starter
MrXC2014's Avatar
Default Fuel Leak????
Ok I was getting ready to ride my bike this evening and as it was running I notice fuel on the ground but I couldn't see where it was coming from on the bike I immediately shut the bike off then got my water hose out and started rinsing the motor and floor off. So if my fuel line at the back of the tank popped off, would this be the reason for the fuel leak that is shown in my pic? I haven't looked yet cause I will have to pump the fuel out of the tank to be able to lift it just trying to some conformation!
2014 Victory CC, Two-Tone, VM1-HPT-DR, PC5, ATS+4, Llyodz HI-FLOW A/F, 1/4 Turn Throttle Ring, Tuned by Kyle Crandall of KMC PowerSports, Flashed ECM, 121hp 113tq
Suede Supersteel & Black, Madison, AL
MrXC2014 is offline
post #2 of 7 (permalink) Old 07-09-2019, 09:37 PM
If the line popped all the way off; it shouldn't leak and of course your bike wouldn't start but if it's partially off and partially on it could leak and still run. A break or hole in the line might do this too.
Yeah, good idea to pump the fuel out of the tank first, then lift it off to see what's what. You might be able to see enough simply by pulling the right side cheese wedge and lifting the back of the tank without pulling it all the way off.
post #3 of 7 (permalink) Old 07-09-2019, 09:56 PM Thread Starter
MrXC2014's Avatar
Isn't the pump where that back fuel line is connected too, so fuel would still becoming out rt or I'm missing something?
MrXC2014 is offline
post #4 of 7 (permalink) Old 07-09-2019, 11:16 PM
What I can tell you from experience by trying to pump the fuel out using the fuel pump and a disconnected line is it will only pump a small bit of fuel before the pump stops. Now I don't know if some kind of fuel pressure sensor tells the fuel pump to stop or how it works. I thought maybe there were check valves in the connectors but if there were; I don't think it would pump the little bit that it does.
I'm not a master Victory tech; just a shade tree mechanic. I wish I could explain it better. Back when people like KevinX used to grace us with their presence; it made things easier. You could try contacting Rylan or Kevin directly if someone else here can't shed more light on why it happens like this.
post #5 of 7 (permalink) Old 07-10-2019, 05:28 AM
depot picker's Avatar
Is that puddle all fuel or had you rinsed it?
depot picker is offline
post #6 of 7 (permalink) Old 07-10-2019, 07:33 AM
gamewarden's Avatar
The other day I had the fuel line at the fuel rail pop off. Gas all over my leg and bike died. The plastic clips that hold the end of the fuel line on both ends sometimes fail especially if they don't click when put back on. I had been going over some construction and I think that helped dislodge the clip.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #7 of 7 (permalink) Old 07-10-2019, 08:41 PM Thread Starter
MrXC2014's Avatar
Yes that is all fuel, the culprit was the fuel line connected to the pump was not connected correctly after tugging on it, it seemed to be good to go until I started the bike and let it run and once I lifted the back of the tank up, Bam! fuel leaked, so I rechecked the fitting with the help of my buddy and discovered that it was not locked on properly. Lesson learned, listen for the click on those fuel lines.
depot picker likes this.
MrXC2014 is offline
