Throttle cable electrical connector? - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 07-17-2019, 12:10 AM Thread Starter
rojo154's Avatar
Default Throttle cable electrical connector?
Had the tank off to do an installation when I noticed an electrical connector unplugged. It looks like it is part of one of the throttle cables.(right side by throttle bodies) The opposite connectors are neatly tie wrapped to the wiring harness on the frame so it is not something that someone just forgot to reconnect.For the life of me I have no idea what this would do?? Would it have anything to do with having cruise control that they have been disconnected?
2011 Kingpin
custom paint
Ness fly bars
xbow exhaust
S&S air intake
Dobeck fuel controller
chrome floorboards
cruise control
2004 Kingpin
Victory performance exhaust
customized air box / K+N filter
LLoydz fuel controller
custom oil lines
custom led lighting
custom led third brake lights
Sold ..( my baby, still have some sellers remorse)
2011 XC
rpw exhaust
wiseco fuel controller
Sold
rojo154 is offline
post #2 of 4 (permalink) Old 07-17-2019, 05:34 AM
WeekendRider's Avatar
On the XC there is a "switch" built into the throttle cable and two wires connected to it. It's what shuts off the cruise control when the throttle is pushed forward. This switch is often a problem on the XC when water gets in the connections and keeps the cc from being able to be set. I have had to disconnect mine. The only loss is the ability to cancel the cruise when you roll the throttle off.
I'm not sure if this same situation exists for the other models.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #3 of 4 (permalink) Old 07-17-2019, 12:47 PM Thread Starter
rojo154's Avatar
I'm sure by your explanation this is exactly what this is. The female part is built into the cable casing and the 2 female connectors are zip tied above. I just left it alone. I am not too concerned as I am not a fan of a cruise control on a bike. The unit just makes the oil filter hard to get at so I just buy the filters with the nut on the housing. Thanks for the response, it cured my curiosity.
2011 Kingpin
custom paint
Ness fly bars
xbow exhaust
S&S air intake
chrome floorboards
cruise control
2004 Kingpin
custom oil lines
custom led lighting
2011 XC
rpw exhaust
Sold
rojo154 is offline
post #4 of 4 (permalink) Old 07-17-2019, 01:32 PM
when you ask these kind of question add a photo please
